My car is a R33. Jus cracked the 100,000km mark. I have noticed a loss in power at about 2000rpm, as i accelerate past 2grand it hesitates up to about 3grand. Could this be a timing a problem and therefore getting a new timing belt fitted would be the solution, or is this sumthing like a coil problem..
I dont know much about car mechanics, but i know enough to buy a skyline.
https://www.sau.com.au/forums/topic/77368-hesitation-between-2-and-3000rpm/
You should change your timing belt at 100kms unless its already been done, regardless of a miss.
Your problem sounds more like a spark related issue, ie. plugs, coils, ignition module, etc.
Does it happen when the car is warmed up? is it very consistent? does it come and go? Is it really bad or is it just one cylinder? I would need more details. But that isnt to say that some one else can't tell from the information provided.
Yes it happens when the car is warmed up although it is more noticable when its cold, it happens everytime i guess, depending on the circumstance its more noticable than others. Its not REALLY bad, but i have noticed a power loss, i guess that could mean only one cylinder but i really wouldn't know. Thanks
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
