Hi guys,
I have the following parts for sale...all in perfect working order & excellent condition.
FYI - reason for my sale is because I have just spent over 25k on modifying my own GTR :) silly me.
Pics below for your reference.
They are all from my Australian Delivered GTR.
Turbos (1 turbine is bound with carbon, although they did produce 242awkw at CRD on 17psi) - $700
Dump pipes - $100
Complete exhaust - $400
Cam shafts - $300
Cam gears - $100
Air flow meters - $300
Coil packs (x6) - $300
Complete front & rear suspension - $400
Computer ecu without speed limiter - $300
GTR R32 rims with 40% tyres - $900 NOW SOLD
Injectors (x6) - $300 NOW SOLD
If any of my above pricing is unreasonable please advise...pm for further details & contact.
I am based in Sydney.
Thanks,
Marko
0404 884 876
Edited by Marko R1
Hi Adam,
$250 for the injectors is fine, its all yours mate!
Once you transfer the funds i'll post the injectors to you monday morning - i've got the day off :(
Here are my bank details...
bsb: 732065
acct no: 615106
acct name: marko radojcic
bank: westpac
regards,
marko.
Hi guys,
I still have the following parts left...
Dump pipes - $100
Cam shafts - $300
Cam gears - $100
The above prices are negotiable, I have absolutely no need for these bits...
Any offers out there???
I'd rather see them go to good use than sit here with the chance of my parents throwing them out 1 day from shear frustration, this has occured once before ;)
Regards,
Marko.
0404 884 876
  • 2 months later...
Marko, will the exhaust fit a r32 GTS-T?
Hi Nick,
The exhaust will fit an r32 gts-t although the front pipes are twin for the twin turbo setup whereas the gtst would use a single front pipe...other than that its fine mate :)
Marko
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
