Looks can be deceiving. It's supposed to be 20% less throw length, not shorter in length. But I believe it is slightly shorter.
U want a shortend shifter. Take an angle grinder to yours then weld it back together. U want to be able to shift quicker, buy one of these babies.
Ok, sorry for the confusion guys. It looks like this shifter is only for R33 GTST Boxes. So my appologies to all the guys with R32's that PM'ed me.
If your keen to get a hold of one thou. This is where mine came from http://www.justsr.com/forum/viewtopic.php?t=85
Tell greg your from SAU and should pass on a discount, as a group buy was done a while back and he surely made some cash from us.
I have been telling people that I will ship it for $10. So i'll make that open to everyone. Dont PM me asking for a reduction in price! This is a bargain IMO and i'm already loosing money on a new item. Thanks.
It did fit into the box and it did shift gears. However the throw length was not decreased and the bush on the end of the shifter would not stay on for some reason.
Also the shifter itself felt longer in length. I was told by Greg @ JustSR that at the time of this group buy there were not manufacturing short shifter to suit the RB26 Box. However they do have some 'new designs' now.
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
