If it's a track requirement it has to be in reach of the driver when strapped in as far as I can guess.
I'm mounting mine to the raised floor part behind the glovebox (the tunnel that the driveshaft goes under).
I know of people who have mounted it in the passenger area (although I kept away from that to stop them from getting a fire extinguisher in their knee incase of an accident).
Also seen people use a plate to mount them to the seat rails and have it just behind them.
Don't get the crappy noname/cheapy ones from autobarn/repco/wherever. Mine leaked all over the place (both of them) and when I had a fire they were both useless. Garage-13 sell chubb ones pretty cheap.
I made a bracket up & bolted the extinguisher to the front of the drivers seat rail. Means you can't move the seat forward, but as I don't share the car with anyone - who cares. When you buy your extinguisher get one with a metal bracket (Mine is a Quell) & also have a look at the date stamped on the handle - go through the boxes & find the most recent.
Mines bolted on near the passengers left leg. The seat can still be adjusted all the way and it doesnt get in the way of the passenger getting in and out. And easy to fit there, no making or adjusting the brakcet that came with the extinguisher.
  • 3 months later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
