WHEELS IN STOCK!!!! NEW NEW NEW
Here's a list of the wheels and available sizes.
These are available with or without tyres as of July 1st.
PRICES AVAILABLE NOW!
****NOTE**** Offsets to suit most popular vehicle makes and models.
Some wheels listed can be ordered in staggered sizes. Please take note of the size range listed for each wheel model.
GT-R Specific wheels are in the Konig range.
This is what's in stock at the moment. No waiting!!
PRICING AS FOLLOWS
DR range including RSGT
17" $1040 inc tyres $1600
18" $1400 inc tyres $2120
19" $1800 inc tyres $3000
Konig range
17" $1420 inc tyres $1980
18" $1880 inc tyres $2600
19" $2600 inc tyres $3800
20" $2860 inc tyres $4200
Katana range
17" $1120 inc tyres $1680
18" $1480 inc tyres $2200
19" $1880 inc tyres $3080
Why such skinny wheels Charles? The Koenigs are about the only ones that are 8inch or wider. I thought you would have got wider wheels.
I'll be keeping an eye out to see what your prices are tho, especially on the RS-GTs, but I don't know what kind of tyres I can get onto a 17x7inch rim.
7inch is 177.8mm, so I'm thinking around 225 might be around the max, but I'm not sure.
If you've got anything else available soon, new or used, with or without tyres, for R32 GTR, let me know (She gets into Sydney this week)
The sizes listed with every picture are the only sizes the manufacturers make.
I'm also looking into other models that will be more Skyline GTS and GT-R specific.
These however are what i have in stock at the moment.
Prices available and tyre package listings from the first of July (new financial year)
Thanks for being patient guys!!
Charles.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
