  • Replies 97
  • 3 weeks later...
we MIGHT have it in before DECEMBER cant say how i know i just do.
Was supposed to arrive into the pumps at Selfs Point last month, but the safety team they set up to assess the setup deemed the setup unsatisfactory so we now have to wait a bit longer while they set everything up again to pass the safety inspection.
Oh and 98RON petty will be 2c/L dearer than ordinary 95RON petty :D.
This all came from the manager at Shell North Hobart, so it aint bullshit :D.
https://www.sau.com.au/forums/topic/78592-pulp-98/page/2/#findComment-1527030
Ive got a Microtech LT-8, thinking about upgrading to an LT-12 but there isn't much difference except more inputs/outputs. oh and the cost factor.
Do you know Paul with the White S4/5 RX7 (think he was at the drags) pretty sure he gets ELF or C16 or something from MOTO sports on Killafaddy Rd, i am pretty sure they get all that stuff in
was your 300rwkw run made just on plain jane 95RON Premo?
https://www.sau.com.au/forums/topic/78592-pulp-98/page/2/#findComment-1528853
yeh, MOTO get anything you want, I used to get toluene from them. Keen to want to spend that much on petrol though.
Off topic, who you getting to tune it tim? u got a new turbo yet?
Edited by phat_r33
https://www.sau.com.au/forums/topic/78592-pulp-98/page/2/#findComment-1529244
Went into MOTO today they have 102 octane for about $90 for 20litre drum.  He said they might be getting some 110 octane he will let me know when it arrives.
be good if you could keep us posted about it mate :)
Cheers B
https://www.sau.com.au/forums/topic/78592-pulp-98/page/2/#findComment-1538700
Yeah let me know how u go with the fuel as well, as it is now gettin to high 300's for a 200L drum of bp ultimate which i use in the gtr and i will also use it in the race car and its gettin fairly expensive for pulp fuel.
cheers matt
Edited by BLUEGTR
https://www.sau.com.au/forums/topic/78592-pulp-98/page/2/#findComment-1540308
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
