  • Replies 97
I look forward to the ANDRA Sports compact day. should be good. Aslong as my car is running as it should.
BWAHAHAHHA
yeah i hear what your saying.
So much to do, so little time and not enough day light :rolleyes:
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1555293
when someone else is doing the work you can be a bit more pushy though... i want my car back in time  BIATCH!
yeah well i wouldn't want you giving me the stand over tactics TIMMAY!!!!
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1555345
  • 1 month later...
Hmm why does one servo tell you they will have it in a mater of months if not weeks and another tells you that tassie will never have it???
Is my car any closer? No, have i got a big shiny turbo yet? no, Have my hubs turned up yet? No.
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1635571
Yeah i know the feeling.
I have held of tuning my car in the even that it may of come down and it wasn't just BS that everyone was posting (should of know better <_< )
My car is no closer either Tim, but an up side.
I think i have found a Q to race :D
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1640088
you have too much money benny boi, share the love
WTF
Its a Q champ.
You buy a ready to race, roll off the tralior for $3k
THrow some tyres on, slap some happy gas in and your ready to race for $200 :lol:
Oh and i would love to see the look on Toff's face when he can't catch me :(
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1642813
  • 1 month later...
Launceston Tasmania
Legana Liberty have it, i only just found out... dunno how long its been there, the guy there said that he would expect all other liberties to follow suit
I am going there tonight just to check it out
please explain? where exactly is here
Edited by Edstrodamous
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1720928
hmm, do liberty buy their fuel from one of the major suppliers?? If so, which one.
Well i hope its on its way down south as well.
make life a hell of a lot easier thats for sure.
Otherwise its a pretty long trip up north to fill up everytime :)
Cheers B
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1721519
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
