  • Replies 97
I look forward to the ANDRA Sports compact day. should be good. Aslong as my car is running as it should.
BWAHAHAHHA
yeah i hear what your saying.
So much to do, so little time and not enough day light :rolleyes:
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1555293
when someone else is doing the work you can be a bit more pushy though... i want my car back in time  BIATCH!
yeah well i wouldn't want you giving me the stand over tactics TIMMAY!!!!
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1555345
  • 1 month later...
Hmm why does one servo tell you they will have it in a mater of months if not weeks and another tells you that tassie will never have it???
Is my car any closer? No, have i got a big shiny turbo yet? no, Have my hubs turned up yet? No.
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1635571
Yeah i know the feeling.
I have held of tuning my car in the even that it may of come down and it wasn't just BS that everyone was posting (should of know better <_< )
My car is no closer either Tim, but an up side.
I think i have found a Q to race :D
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1640088
you have too much money benny boi, share the love
WTF
Its a Q champ.
You buy a ready to race, roll off the tralior for $3k
THrow some tyres on, slap some happy gas in and your ready to race for $200 :lol:
Oh and i would love to see the look on Toff's face when he can't catch me :(
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1642813
  • 1 month later...
Launceston Tasmania
Legana Liberty have it, i only just found out... dunno how long its been there, the guy there said that he would expect all other liberties to follow suit
I am going there tonight just to check it out
please explain? where exactly is here
Edited by Edstrodamous
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1720928
hmm, do liberty buy their fuel from one of the major suppliers?? If so, which one.
Well i hope its on its way down south as well.
make life a hell of a lot easier thats for sure.
Otherwise its a pretty long trip up north to fill up everytime :)
Cheers B
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1721519
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
