i can't rememeber the details or who made it, but i actually studied that artwork in my HSC last year. it was constructed from leather and suade.
Its actually real i thought i was just a photoshop job? HOLY FARK! that makes it 10times freakier
https://www.sau.com.au/forums/topic/78621-is-it-scary/#findComment-1435621
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
