Hey guys and gals.
With the new Cams, my car is sucking the juice like you wouldn't believe.
I got 410 highway kilometers on a trip to Albury and back recently.
I think my cruise ratios are at about 13.2:1
What is ideal, and what other things could be effecting my fuel economy?
I've only recently changed my oxy sensor.
BASS OUT
what city driving like? im happy with 400+ odd kms from highway driving
my r33 sits on 2800ish all the time at 100km/h so 400km's is resonable in my car on highway.
city driving i get around 320km ish to a full tank. i dont let it run empty or wait for light, one the needle is on the low line i fill up. im assuming youve made sure 02 feedback is on and what is the value for 02 under sensor check like at idle. its a shame you can't monitor 02 under monitor and plot it on graph, would be handy. strange that cams would have such a drastic effect on fuel economy?
I get about that many k's. Get us some L/100Km figures and then we can make a better judgment. For all we know you could be filling up 40L instead of 50-55.
I've also got a consult cable which connects to my laptop and logs just like paul is saying.
I recall SK saying that with cams it can make the car run rich in the mid range so maybe since that's where you spend all your time driving...
Also, has your idle been raised slightly compensate for roughness induced by the cams? Only a couple of hundred rpm can have a huge impact on fuel use.
I've been told that with reasonable size cams, that 14.7 is far too lean....
You burn exhaust valves.
Is this correct?
Depends on how big your cams are.
SK has said in a previous post that too lean a mixture even 14.7 for big cams will burn out your exhaust values. I spoke to my tuner about this and its true, also you would be lucky if the engine would even take that ratio without surging.
Best to get a tune first when ever you make any mod that will change the volumetric effiency of an engine. Cams fit this category for sure!
Another thing: cruise ratio's of 13.2:1 is running on the rich side. In Closed Loop you should be able to run the 14.7:1 ratio or even leaner but depends on cam sizes.
What are your new cam sizes BTW?
Cams are Poncams, 260 degree by 9.15 lift.
So you said that 14.7 would burn valves, but you also said that in closed loop I can run 14.7.....
What say you?
Yes I said this but for BIG cams like 280 degree or maybe even the 272.
The cams you have fit in the MID type range with a lift on the small side. These are a great cam and I'm getting a set myself but with 10.25 lift as I have that lift in my cams ATM.
In closed loop it aims for 14.7 in light city driving & 14.7 or leaner if your ECU is capable - leaner mixtures for economy.
I'm changes my cams for this exact reason, I can't go any leaner around 13.1:1 because it will surge or its too lean for my exhaust values and they would burn out.
With a tune they would be able to see what AFR you are able to run across all load & rpm points to suit your cams then setup your closed loop.
How do I do this with the Power FC?
This has to be done on the Dyno with a wide band UEGO sensor for your AFR. With this information they can set the fuel delivery maps. If you have adjustable cams gears, they will be able to set these for your new cams as well.
The timing has to be set as well for load & rpm points.
Another thing is these cams should give you more power if this was an upgrade so getting it tuned = more economy & power....hmmm nice combo.
Always use a reputable tuner though, no good having the right stuff and someone not setting it right = waste!
These cams actually cost me power!
Check out my other thread about it!
OK, interesting read!
I agree with SK, Installing bigger cams means you are allowing more air & fuel to be let in per cycle - less restrictions but in your case you can get the fuel there in the right quanity but run out of air, re your stock turbo. A high flow, GCG or something bigger then your stock will fix this for sure. You would of noticed the difference when you turned up the boost - right? Well wait till you see the difference with a high flow or bigger turbo....wow factor!
Also, talking to Benno (Racepace) will confirm or change what needs to be done. I also believe (without knocking anybody) he is the tuner thats ends all tuners. Wish he was here in sunny Queensland. Trying to convice him, hahahaha.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
