Just wonderin, My stock boost is set at 7psi ( for now anyway ), the aftermarket BOV i wanna put on is from a m8s R34 which was set at about 15psi, so the question is: Can i just wack on the aftermarket one and it will be ok or do i have to adjust the BOV so it works with 7psi. This may be a silly question but does the amount of boost make any difference to the air pressure left in the piping when the throttle is let off??J
https://www.sau.com.au/forums/topic/78707-boost-pressure-with-bov/
Ummm.... boost IS THE PRESSURE IN THE PIPING... so its the same as the speed you are going DOES make a difference to how fast you are going....
Why are you talking about BOV setting boost levels?
BOV's DO NOT CONTROL boost. They are just a valve, a blow off valve infact. It will open when the vacuum lines sucks the valve open. The tension in the spring is something you may want to consider, a heaps hard spring won't open as easily but will limit leak.
i was also wondering how much boost the stock bov can handle before it leaks, as i want to run 18 - 19psi on my rb20, and i was thinkin the stock one would open up at that sort of pressure so i was thinkin about getting a greddy type s bov, but only if it was needed,
all your help is appreciated.
20 lb on stock block = disaster dude....about everythign is wrong with runnin that much psi on an RB20 with no mods to ur pistons..injectors...fuel pump....cams...as for the stock bov i thought they were effective to handle 14-15 lbs could be wrong here howevere
mate has a r31 with r32 rb20, stock cams,stock engine, just forged pistons.
runs 20pounds day in day out, tuned with a microtech ltx8
running for over 40,000klms!
    • The front prop shaft from my GTR had very notchy unis, which obviously needed replacement but unfortunately uses the (usually) non-replaceable (staked) type.     A new shaft is something like $2K plus shipping from Japan.   I wouldn't even bother asking the local Nissan spares dept.     Rang Hardy Spicer but no go, which surprised me a little.     There's a place over Dandenong way that would make me a 'performance' shaft but un-necessary in my situation.   They claimed to be getting the equipment in to replace staked unis but couldn't give me a timeframe.   Anyway, long story short, found a place to do the work just 5 mins from me: https://knoxdriveshafts.com.au $420 (cash) and about a week later I have my driveshaft back.   Price includes balancing. Owner is a one man band working out of a shed in his backyard but from what I could see he's very well setup with some expensive equipment.
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
    • oops that seems much easier lol.
    • Are you using the factory rail?  Is there any reason you don't want to use one of the two you already have, they don't have to attach to the fuel rail directly.  If you 100% must have a FPR that directly bolts to the fuel rail, you could get a Radium setup. I use a radium fuel rail and the direct mount regulator, it is quite a sexy setup.
    • https://www.google.com/search?q=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&sca_esv=6710113de42d5150&source=hp&ei=GhPbaNHfNZeinesPyPqEiQc&iflsig=AOw8s4IAAAAAaNshKnLkjQGMWYT5EyclmXEJm8ZXSWDb&ved=0ahUKEwjR1JOCjf-PAxUXUWcHHUg9IXEQ4dUDCCE&uact=5&oq=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&gs_lp=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_EFhqEHecdnjv2SBwYyLjU1LjGgB7XnArIHBjAuNTUuMbgH4UXCBwgwLjUuNTEuMsgHiQI&sclient=gws-wiz
