  • Replies 94
Originally posted by kabab
Gues what.......
He sold the rotor !!!!
As for the matter at hand REV's efforts have proven its possible, we just need to see it happen with a few other similar spec'd R33's to know its not a freak car.
Well I'll be damned, he sold it! It was just starting to get interesting too.
Remember though REV's car still has a few *important* minor mod's.
  • Exhaust
  • Turbosmart bleed valve - minor but a mod none the less :P
  • Upgrade clutch & light flywheel combo
  • S-AFC II - dunno if this contributed to xtra power for his 13.4 run or not? REV?
Lightflywheel improve's you acceleration through 1st and second especially.
Which is very important. :P
Had a little squirt with a Maloo 255LS1 Manual Last years model Ute the other morning.
It was actually slower much slower than I expected. Out accelerated even in high rev's through third. Their second gear is also a little slow. They launch so damn well though he grabbed 1/2 a car length in front then by second i was already side by side, third i was sailing past.
He started it, and was 40+. He drove like a boy racer.
Originally posted by 2fardown
Yes you are right...I run Simex 225's and they grip like mad.
I thought that Simex [tyres] were ok and not that cheap :confused: Mine are the 235 / 45 variety on stock 17x7.5 wheels...The model number is sm8200 i think.
Would b nice to find out about this slicks / elf 33 drag time!
I run 2x 225 50' 16's Simex on the front, the rears at the moment are Baraums which were $149 each but are really chirpy tyres and don't grip. I'm waiting for them to die.
The Simex tyres were $138 each which is pretty cheap compared to the Bridgestone, Yoko' etc price of $200+
13.4 is a 'can do' with some important mods, you won't get the stockie going like that un-fortunately cause of the exhaust if nothing else.
My 205's , even tho simex, are way under sized for road rubber let alone the drags.
Didn't do a thing with the s-afc II except watch the pretty blue screen for 'knocking'. I only installed it the night before and since the instructions are all in jap i was not prepared to touch the A/F settings, I'll leave it for the dyno some time in the next month.
Note: * that I did a bunch of 13.5's and a 13.6 that night, it's no fluke.
* Simex (read cheap'o) 205's, no octane booster , stock ecu , stock intercooler, 10psi.
[quote[i think mid 13's are possible may be a 13.4 babs is on the mark you dont need a bigger cooler unless you are fitting a bigger turbo in reality merli made reasoanble power witha stock cooler.
meggala
nice to see I"m not talking sh1t
great effort rev210 with some tuning and boost watch the times tumble also dont forget the motorplex is one of the fastest drag strips in the southern hemishpere. ithere is at least a .3 sec advantage there
meggala
  • 3 months later...
Actually i remember andrew trap speeds where higher then mine around 98mph ???
Your forgetting the ELF :( thats bound to give you abit more power..
I guess there is only one way to find out :)
By low 13's i mean 13.3 - 13.0
just reading thru old threads, can someone plz explain to me exactly how elf or anyother fuel/oct booster can make any difference speed wise at all in a standard car? how are you going to advance the timing kabab?
Many people think that using high octane fuel will automatically give a large or significant power increase. This is not neccessarily true. High octane fuel has a slower flame front propagation during combustion which helps prevent knock when used in high compression engines. Since stock Jap engines are designed to run on 103 octane petrol they will not have high enough combustion pressures or temperatures to take full advantage of a 124 octane fuel. In fact using too high an octane fuel can actually reduce power because the fuel burns too slowly to produce peak combustion pressure high in the power stroke. To get back on thread I doubt that using Elf racing fuel would give much of a boost to a stock engine. So getting into 13's with a stocker on Elf is unlikely.
You keep talking about this Elf stuff as if its gonna turn a stock RB25 into a huge beast!
And what your suggesting, tuning the car to run on elf, is not something that youd do just for one run. Whats the point in saying i did 13.x on elf, when your cars not tuned for it for daily use? And even if you tuned it, without a programmable computer you cant do a whole lot to "optimise it".
And anyway, its my understanding that a higher octane fuel protects against detonation. It burns slower, which is why you can up the timing to get a bit more power. But the real gain would be seen by upping the BOOST, which your not gonna do coz then it wont be stock.
And yeah, what BigAl said!
Well IMO doing stuff like fitting <18psi Nitto 555R drag tyres and all the little tricks like removing the spacespacer and stuff is kinda cheating a bit.
It's the same as dyno runs. I'm sure some of you use octane booster and up the boost but is it all kosher that way?
To run that magic 13.4 is a far bit of work in itself and it almosts turns the car into 'not a daily driver'.
T.
Sold a Computer case to a bloke today that had a TF Cortina.
Pretty wild cam to say the least. You don't even year V8's idling the way this thing idled.
Sounded absolutly awesome. Especially for a six.
Apparently he claims he ran a 13.2 1/4 with sticky tyres on the rear.
Apparently it makes power to 6000rpm which is pretty good considering the standard 250 six's peak power is at 3700rpm.
Still in Awe with the sound of the think actually.
Notice I said a lot of Apparentlys :P
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
