i own a R32 GTR for a lappo, & a 10sec Rx3 coupe, rotaries are a cheap way to go fast! my rx3 runs 10.63 on a std import 13b eng, with a high flow turbo. very cheap & very easy to do. now im currently porting the eng & im going to run a large turbo (GT42 ..T76) & that will push the car into the 9sec bracket! early rx's hold their value very well & its going up every day!
  • Replies 41
Hold on, hold on. In one revolution of a rotary engine 100% of its combustion chambers ignite (if you understand what I mean). In one revolution of a cylinder engine 50% of its combustion chambers ignite (not taking into account 5 and 7 cylinder engines BMW produced). So the ratio is 1:2. i.e. Rotary conumes twice more air and fuel than the cylinder engine of the same displacement.
However the rotary still makes 3 power strokes.
with the rotaries combustion cycle for one complete revolution of a rotary it fires 6 times. so a 2 rotor 12a,13b is the equivalent of a 6 cylinder and a 20b 3 rotor is the equal to a 9 cylinder engine
for me I love the fact that something so small can create such a great amount of power and I LOVE the sound of a rotary especially the 20B mmmmmmmmmmmm
  • 4 weeks later...
Sorry to drag up an old thread, but I was under the impression that it wasn't really as easy as putting on a high flowed turbo to a standard engine and then running 10's. Don't you still need engine management, bigger fuel system etc...?
I had a 12A bridgeport RX7 for about 2 years. Most people have answered this thread but I thought id add my bit..
They Rev hard.. And I mean hard.. I changed gears at about 6'000 rpm and it would pull very hard.. pull very hard towards the bank! As it used so much damn fuel it wasnt funny, Id put in about $45 in and get about 250ks from it.
True, engine management would be a must have and if you wanted to run 10's then yeah I think you would need a bigger fuel system.
Dammm... I want a rotary now... No actually... I want a ZTUNE first... then an RX7. :drooling: Rotaries sound like a lota fun, I like the idea of putting a 'f#ck off how big is that' turbo under the bonnet. I seen the RX7 with licence plate "13G" with a set up like that... was so nice.
That 13g rx7 (can see it on city performance website) actualy has a 13g engine in it, which is a factory mazda race engine with factory peripheral ports.
yeah I had a good look at it in person probably about 7 months back on a cruze, it is an amazing RX7 thats for sure.
Lookie lookie what I found :D I took these back on that cruze....
"big turbo did you say???"
It looks even bigger in real life... Look, you can even see the gold MoTeC box on the right... :drooling:
Meh, mine made 400hp on 6psi so it doesn't seem that odd.
Rotaries compare like this
13b comparable to a 2.4 or 2.6 L 4 or 6 cylinder piston, depending on who you talk to.
Mazda actually measure the displacement the "proper" way, if you want to compare a rotary to a pistons displacement you have to double it.
so,
13b = 2.6L
20b = 4.0L
26b = 5.2L
rough guide but you get the idea
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
