I have just recently purchased a R34 4 door and i am in search of suspension products for my car. I already purchased a set of HKS coilovers, but i am also searching for other parts like adjustable arms front and back, sway bars and anything else to fit the 4 door.
Everything i have been searching for is just for the 2 door. I am wondering if anyone knows the differences, if any, that there are between the 2 door and 4 door R34 skylines. If anyone has any knowledge on these i would really appreicate the help since i would love to be able to order some cusco arms asap if i can find out if they fit or any other type of brand out there.
Thanks in advanced for helping this noob!
https://www.sau.com.au/forums/topic/78847-r34-4-door-and-2-door-suspension/
nismo do arms for the 4 door and 2 door they also do stabilizer bars for the front and back...ummm im going off memory...i will probably have more for you later as in differences in the 2 door and 4 door later on tonight as i dont have the info on me ...
hope this helps will post more up later.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
