  • Replies 57
Footy training is on tonight... Halfway through the season now.
Pete and Mark u gotta get ur asses down. Whats this turning up for pre season training and not playing a game shit???
And Pete i'll be buying you some boots soon.
The h&j have awesome $10 steaks after training. :P
https://www.sau.com.au/forums/topic/78862-beers-tonight/#findComment-1439215
f**k me. even jaala is more hard core than pete. no wonder, she does drive a 31 after all. it seems she also has the balls to back it up.
Jaala, just so you know, if it's your first night at RSL payday drinks you buy the first 3 rounds. at least that's what pete told me when I first showed up... :Oops:
https://www.sau.com.au/forums/topic/78862-beers-tonight/#findComment-1439369
hahaha, easy tiger. that photo of you at kareoke has ensured we never 'hook up' my friend. though i must admit you are a very handsome man and you car does put on a solid smoke show. hmmm.
https://www.sau.com.au/forums/topic/78862-beers-tonight/#findComment-1439380
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
