  • Replies 57
It's the resistor pack for your injectors. Its there to change from high impedence to low impedence. If any wires are shaved, try repairing it. This unit can be removed for repair, but for now lets try fixing the problem you have now.
Check No.1 coil very carfully - something might be there
Photo's are there now.........
i already got a new set right here! i just bought some extra ones last time i changed'em,
but they are the same ones ( NGK BCP7E-11 )
also, is it ok if i kept the gap as it is? coz i never gaped one b4, and if i try and end up breaking one am going to be a plug short! hehe!
btw, i couldnt thank you enugh for ur time. uve been a big help
No problem, thats one of the reasons why we are all here, share, talk & help.
Your plugs must be gapped down, its not hard it you have a filler guage. I can guide you through it if you like.
been reading a few threads, and i found this one:
http://www.skylinesaustralia.com/forums/sh...ghlight=misfire
almost the exact semptoms. i realy hope its not a gasket
OK, I have read this post. This is true - if your car runs very rich, it will misfire but if you replace the spark plugs - as I have suggested - it will run fine for a while until it misfires again but we at least know where to start looking.
In any problem solving, process of elimination is your friend. We have to check what works to find out what does not.
P.S. Gapping plugs with even a good Mallet, hammer, brick is a health hazard....... only qualified professional machanical engineer technican should use these devices.
is this what your talking about? coz i found one! loool
Thats the one!!!! Even people like you and me can use this, no qualificians necessary.
1. find 0.6 filler guage.
2. on something soild like a metal bench, tap the spark plug with just enough force to shorten the gap.
3. Contine doing this & check with the filler guage.
4. If you over do it just use the filler guage or something else to very slightly open it up.
5. The filler guage should slide in without moving about or move very slightly.
In your situation because you have 1.1mm gapped plugs, measure from the tip of the spark plugs, they have to be bent a far bit - this is why the BKR6E has a factory setting of 0.8mm gap, better and easier to gap to .6 or .7. Another thing, the 6 is a hotter plug, does not foul as easy as the 7 plug range.
0.6 is probably a touch to small, the gaps on modded GTR's i've heard used are usually 0.65mm-0.8mm... Not sure about 0.6mm but can't imagine it making a huge difference either way - why not aim for the middle of that - say 0.7mm?
oops sorry, I meant 0.7 as your other spark plugs were gaped at these & 0.7 is a good gap to keep. Mine are at 0.6 but I have alot more boost & fuel to iginite.
Sorry about the confusion
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
