  • Replies 57
loool just messing around
heard alot of stories about some stolen gtrs a few years back here, but at the time i was in the US to finish school. the thing is, its not about cheap or expensive, its about finding a place to take of the care and not worry about them fixing something and messing something else. from my visits to many garages (except for a couple), am starting to wunder how the hell did they got some gtrs in the 8's
Hmmmmm, this could explain it then. When you first installed the new plugs, things would of been fine but after a while they would of fouled up as these are a colder plug. This would of caused the misfiring after a while.
So important to:
Get the right plugs for the job first.
Gap then check then re-check again
Pay close attension when make changes & change things slowly to see the result. When fault finding, it makes things alot easier to find.
I've got my fingers crossed too.
Good Luck
WetGTR
U ARE A LIFE SAVER MAN
i raise my hat 2 u
thanks soo much, i would have been still wandering if its some wires i played with, or bad gasket.
THANKs
No problem there GTR4ever
Well done, glad to hear all is well. If it happens again try to order the correct spark plugs. This is a common problem with our cars and its always very handy to have a set of plugs handy for just this type of thing.
Always start simple & work from there.
Remember its BKR6E are the ones to get. Gap them to 0.7. This will keep you out of trouble.
Also now you know what afouled plug looks like, so you can just replace that one in future.
PM me anytime in the future for any help.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
