  • 3 weeks later...
  • Replies 378
hi,
sorry if i am posting at the wrong place but i tried searching for the the correct topic but cant seem to find it (maybe using the wrong keywords).
i just bought a 1991 r32 gts, it has a set of D2 coilovers which are way too hard for my liking. The springs also seem short as i can't seem to wind it up to increase ride height.
my question is what are the best spring rates for normal street use and secondly; are there different heights for coilover springs?
Thanks in advance
Rizal
  • 1 month later...
hi Sydney kid
Do mind doing these for me.
l expext them to be pretty hard, my butt can vouch for it.
Front Coil ID: 70mm
Wire Dia: 12mm
# of Coils: 8.5
can you let me know kg/mm please mate...and i'll send you pics of the rear when i get them off the car,or any one eles can do it for me plssssss
cheers mate..
Edited by sun33
  • 1 month later...
Hi SK,
Can you please work out these spring rates?
Front:
Coil OD= 90mm top and bottom
Wire OD= 13mm
# of coils= 8.125 turns
Rear:
Wire OD= 13mm
# of coils= 9 turns
Thanks!
  • 4 weeks later...
I have an R34 GTT with Apexi coilovers, I don't know what the spring rates are but I know it is a bit too hard riding.
What i want to know is the best place, preferably in Eastern Melbourne suburbs, to have this looked at and hopefully get recommendations and possibly alternate springs made up.
  • 1 month later...
ID Both: 1.24100" (in) = 31.5214 MM
OD of Wire: .194" (in) = 4.9276 MM
# of coils: 31.3 turns
I would really appreciate it!!!!!!!!!!
THANKS!!!
Alex
Motorcycle spring, 25 lbs/inch
Cheers
Gary
Centeline
Cheers
Gary
Hi SK,
Front:
Wire OD= 13mm
230 lbs/inch (4.1 kg/mm)
Rear:
Wire OD= 13mm
# of coils= 9 turns
200 lbs/inch (3.6 kg/mm)
Thanks!
Cheers
Gary
hi Sydney kid
Front Coil ID: 70mm
Wire Dia: 12mm
# of Coils: 8.5
cheers mate..
315 lbs/inch (5.6 kg/mm)
Cheers
Gary
hi,
The standard ones, 165 lbs/inch (3kg/mm), Nissan didn't get it that wrong. If upgrading then nothing over 330 lbs /inch (6 kg/mm) in the front and 225 lbs/inch (4 kg/mm) in the rear.
If that gives too much roll for your liking then upgrade the swaybars, 27 mm front and 24 mm rear.
Yes, heaps, all you need to know is the ID, the rate and and the current free height. Then order accordingly.
Thanks in advance
Rizal
Cheers
Gary
these are off a set of Koni coilovers...
F
Coil ID = 64mm
Wire OD = 10 mm
# of Coils = 6.5 turns
300 lbs /inch (5.5 kg/mm)
R
Coil ID = 64mm
Wire OD = 10 mm
# of Coils = 7.1 turns
265 lbs /inch (4.7 kg/mm)
Thanks SK!
Nice rates
Cheers
Gary
Hi SK could you please calculate some spring rates for me.
FRONT:
Coil ID = 99 top / 68 bottom (mm)
Wire OD = 12.7 mm
# of Coils = 7.5 turns
275 lbs /inch (4.9 kg/mm)
REAR:
Coil ID = 88.5 top / 77.5 bottom (mm)
Wire OD = 12 mm
# of Coils = 11 turns
140 lbs /inch (2.5 kg/mm)
With 11 turns it's most likely a progressive spring, give me the coil spacing and I can work out the high rate as well (140 is the low rate).
thanks, Tim.
Cheers
Gary
Hey Gary can you please work your magic formula over these,
Rear
OD:- 92mm
Coils :- 8.2 turns
Springs Diameter :- 12.9mm
220 lbs /inch (3.9 kg/mm)
Front
OD :- 95mm
Coils :- 10.1 turns
Spring diameter :- 14.3mm
215 lbs /inch (3.8 kg/mm)
Thanks in advance
Cheers
Gary
Thanks in advance for the calculation SK,
My front one are
Coil ID = 70 mm
Wire OD = 13 mm
# of Coils = 9.5 turns
360 lbs /inch (6.4 kg/mm)
and the rear are
Coil ID = 59 mm
Wire OD = 12 mm
# of Coils = 12 turns
300 lbs /inch (5.4 kg/mm)
Cheers
Gary
Hi SK
Can you help calculate my spring rates please. HKS coilovers for S13. Hypermax D. I'm guessing pretty stiff :)
Not sure what to measure when it comes to the Coil OD's as I have progressive springs. So attached pic for your assistance.
Fronts:
Coil OD lowest coil 82mm/very top coil 82mm. Widest part of OD is the middle of the top 5 coils and that measures 95mm. 5 coils at top close sprung.
Wire OD = 11mm
# of coils = 10.5
Spring Rate =
Low rate 115 lbs /inch (2.0 kg/mm)
High rate 285 lbs /inch (5.1 kg/mm)
Rears:
Coil OD lowest coil 87mm/very top coil 87mm. Widest part of OD is the middle of the top 5 coils and that measures 95mm. 5 coils at top close sprung
Wire OD = 11mm
# of coils = 10.125
Spring Rate =
Low rate 100 lbs /inch (1.8 kg/mm)
High rate 260 lbs /inch (4.6 kg/mm)
Thanks :banana:
Sam
With those low low rates it would always be running around on the high spring rates, the extra coils are just there to soak up space (keep the coils trapped at full droop).
Cheers
Gary
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
