  • Replies 299
Originally posted by ice180
so we can capture all ambs sexy moves?
hahaha
nooooooooooooooo!!!
keep the cameras away from me unless u want my knee lodged into ur manhood!
hahaha
i will be too busy running round trying to keep things in line!!
heheh yesh lil me .. ooohh supawomann!!! :run:
and keepin the heros from pulling ful shik shkids at the meet point re
there are gonna be too many nice cars there for some silly bois to ruin it for everyone and have the cops show up and have a field day
so if u guys see anyone on the verge of attempting anything heroic please stop them asap!
:D
ambz are you getting aggressive... coz apparently horny chicks get aggressive...
Anyways, I'll bring my camera, along with 128mb of storage and 2 battery packs heheh... and tomorrow morning I'm gonna try out my Scratch X stuff ;) n polish mah beyatch up. The guys from J-Spec should be coming too including a nasty 300zx TT.
Dunno if I'll make it in time tho, I finish work at 8 :D
woooahhhhhhhhhhhhhh
morningggg guysssssssss!!!!!!
gonna be a nice dayy fingers crossed for a nice night aswell!!!
ooooohhhh me and whistla checked out the the cruise route last night
mapped it all out
with some nice stops along the way!
ooohhhhh its gonna be goooddddd
heeheh god damn twistiesss oohh gotta love emm
just hope everyone drives to their own limits
if u dont knwo these roads i suggest u stick to the back and take it easy
no need to rush
so yeah alll is goooodddddddddddddd
skyline33 whistla will be emailing me the map so send me ur email and ill send u a copy
should be an interesting night
dont forget ur cameras!!! oohh a flash will be handy aswell !!
yeee see you all there id most likely be in a black supra or whistlas burgandy 33 or and white 33 gtr so say hello i dont bite (no smart ass comments please)
hope to see u all there!!!!
brendan..
:shake: :shake: :shake:
hihihi just kiddin hun
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
