well the new fmic is fitted and have been driving around a couple of days no problems at all but just as i was on my way to work luckily very close, i started getting a clunking sound coming from the engine bay whenever i went over a bump... i will take it out again in a little while to try and work out were the sound is coming from i checked all the IC piping and and what not and they are definatly all secured and not moving. the only thing i could possibly think would make this noise is if i have snapped my exhaust manifold bolts but either way does someone want to be nice and come help me work out what the fark is going on. I will take it out in like an hour and post back if i still havent been able to work out what the go is ??? as i said seems ok when going on a smooth road just not over any bumps god damn it this is the first problem i have had with my baby hope shes all good :( also any tips on what to look for would be appreciated.
https://www.sau.com.au/forums/topic/79424-helpppppppppp/
As the FMIC is the newest thing in the engine bay I'd be looking at ALL the mounting brackets and anything close to the cooler that could have been obstructed and been knocked loose. The piping is another obvious check point. It will more than likely be something small and stupid but I'd also check the engine mounts and the exhaust manifold. Problems i've seen in my day before.
https://www.sau.com.au/forums/topic/79424-helpppppppppp/#findComment-1447291
:confused: :confused: thanks stevie. Well i took it for a light drive and over a few bumpy areas and didnt hear to noise again ??? i have dropepd it off at an exhaust shop just to get a look over to make sure that i still have some studs holding my dump pipe on. But its got me stumped i had a look myself at the exhaust and it appeared fine. i guess i will wait and see :)
Also other things i have checked
A: everything in the engine bay appears ok
B: Oil preasure is still good holding at the correct levels and is not going dodgy which is reasuring
C: All ic pipings + clamps appear to be on and solid
D: water temp is also fine
E: it is still making boost fine and holding
so yea i am :confused: maybe just the ic piping knocking a little on the engine bay roof ???
https://www.sau.com.au/forums/topic/79424-helpppppppppp/#findComment-1447384
Terminal: that is a possibility but I doubt it as I made sure those 2 nuts were done up real tight plus the front mount is bolted to the chassis so I don’t think it's that.
Frank: possibility though I am generally pretty careful with what I leave in my engine bay and the fact that it sounded more like a metal object clunking against another one makes me think its something pretty solid.
In terms of where the sound was coming from specifically I can’t say defiantly engine bay but I can’t pinpoint the exact location.
https://www.sau.com.au/forums/topic/79424-helpppppppppp/#findComment-1447547
Its the flux capaciter banging up against the centrificul force generator, cost millions of dollars to fix and cant be diagnosed by any one.
Except me.....
so gimme millons of dollars and ill fix it :)
lol well if you say so when i can i drop it around and the check will be dated for cashable year 1000000000 :)
https://www.sau.com.au/forums/topic/79424-helpppppppppp/#findComment-1447625
All work will be completed once check clears, if i cant diagnose the problem ill just take 250k of the millons and give you a nismo z tune (oh and one for myself while im at it :)) Im pretty sure you will forget about the noise in your 33 after that puppy is parked in your drive way lol
https://www.sau.com.au/forums/topic/79424-helpppppppppp/#findComment-1447637
Well I must say that today has been awesome... well now it is this morning wasn’t.
A: we have pretty much secured an apartment we will be buying though not 100% yet and for a good price :).
B: my car is ALL GOOD WOOTTTTTTTTTTT!!!
:headspin: :headspin: :headspin: :headspin: :headspin: :headspin: :headspin:
turns out when I had to cut the 3" whole in the chassis to allow the ic piping to come up through the engine bay I obviously didn’t put enough padding around the edges of the whole as looks like the IC piping must have moved a bit and then hitting the bumps was causing it to knock against the chassis. Anyways had a look at the piping and luckily I did an ok cut job on the whole and clean up as it has done nothing to the piping which makes me very happy.
Anyways will cruze it home slowly then maybe get some rubber thick softish rubber or something similar to put around the piping. Any other suggestions will be taken into account but I think I can look after this one :devfu:
https://www.sau.com.au/forums/topic/79424-helpppppppppp/#findComment-1448038
also bigups to dickson mechanical & muffler service they were to ones who i got to check the car out thinking it was the exhaust manifold studs in the end i guess i should have picked up on it but still they were polite about the whole thing and offered advise on a few other things.
DICKSON MECHANICAL & MUFFLER SERVICE
Unit 2/ 6 Cape St Dickson 2602 (02) 6247 8010
OR... (02) 6247 8322
Fax (02) 6247 91
https://www.sau.com.au/forums/topic/79424-helpppppppppp/#findComment-1448046
You'd still be short around $80,000 for ONE Z Tune in Australia,at the current rate...better up your hourly rate,methinks...
https://www.sau.com.au/forums/topic/79424-helpppppppppp/#findComment-1448239
nice work, just read the thread sorry Lee thats the first thing should always look at, the pipe hitting the side of the hole in front gaurd
well thank you mr lets post a day after i have resolved the issue hehe na only joking shaun i should have clicked myself about it but meh i guess its all about learning :). ps the whole will be plugged currectly with some mega chunky heat resistant foam/rubber this should remove the chance of this ever happening again.
https://www.sau.com.au/forums/topic/79424-helpppppppppp/#findComment-1449874
nice, all i have is the silcone hose maybe i should fix that before it rubs through
lol not sure if it will rub through as long as it the hole has not been done dodgy as i said i made sure the metal surface was as smooth as possible so luckily it hasent cracked/split the ic piping.
https://www.sau.com.au/forums/topic/79424-helpppppppppp/#findComment-1450235
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
