Busselton
As some of you know I went down to Busselton for a bit of break for Xmas. Had a great time as if you think your car gets attention in Perth goe down South, everyone has a look:) There were 2 other lines down there (a black series 1 R33 and a gunmetal R32 with a frontmount,bov and a R33 GTR wing which looked stupid) so I had a few people waving at me and had a little run with the R32.
A friend of a friend down there has just bought that GSR "WRXETA" and I went for a spin in that, no power till 4,000 but after that...wow, he didnt launch it with me in it but I dont doubt its best time of 11.6 on streetlegal race rubber.
Also got some fuel consumption figures for the GTR and they impressed me, about 9.5 - 10L per 100K's. It helps if you reset your ecu before going for a long drive though, makes the ecu forget all your spirited driving :P
Also it is Trev city down there, saw 4 diff. Maloo utes, a TS50, couple of clubsports and a senator or two.
Anyways that it, what did everyone else get up to?
Ryan.
https://www.sau.com.au/forums/topic/7964-busselton/
  • Replies 60
almost dying on Perth Heat!
almost T-boned my best mate's Brand New V8 Commie. :lol:
Broke up with gf :P
Got nice pressies from everyone
Got rejected from girls at the paramount quite a few times...:P
Got Drunk and done few stupid stuff with bottles
Cleaned my room!
I drilled a hole on my car for CAI. -just need few PVC piping.
Had fun with sunday morning rain!
Perth Gory won the PPowers 2-1
I am stuck at work boring.....
cheers
Joe
https://www.sau.com.au/forums/topic/7964-busselton/#findComment-116081
all it deserves
Broke up with gf :P
This a new one or the one who was using u to make her ex jealous
Not me
Lol losing ur touch buddy
U go girl
atleast u don't have a nightshift on newyears eve
cheers
Joe
https://www.sau.com.au/forums/topic/7964-busselton/#findComment-116106
cheers
Joe [/b]
LOL night shift! man that's sucks...
anyway at least you can just pop in to sprit sound bar when you finish! :lol:
cheers
Joe
ps.it's new one I had great time of 40 days of happiness...:P
cheers
Joe
https://www.sau.com.au/forums/topic/7964-busselton/#findComment-116111
Ahhh, Busselton in summer :P
Hot chicks in white bikini's on the beach is all I think of when someone says "busseeellttooon" *sigh*
Which kinda reminds me of a really good idea: A busselton run down south for the day would be a good outing for SAU methinks.
I heard about the success of the last overnight busselton/stay thing, sounded really fun :P
I dunno, how about it guys ? who's up for an event like this ? while the weather is nice ;)
-Kym.
https://www.sau.com.au/forums/topic/7964-busselton/#findComment-116114
Carl has had some dramas with the GSR since buying it off Toby and was quite pissed Toby took off the mags, seats, stereo, cold air intake and was suprised to find that the oil catch can is held in place by double sided tape.
I'm not saying he isnt happy with the car, far bloody from it, just he thought he was getting more :P
But I'm sure they both got a deal that was more than satisfactory in the end.
He needs to ask Toby about the launch control and water IC spray as he thinks its hooked up to the windscreen squirters 'cause they dont work !
https://www.sau.com.au/forums/topic/7964-busselton/#findComment-116544
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
