that looks really nice... i guess the glovebox would be a good place for the AFC but kinda defeats the purpose installing an RSM there...
-ice-
true that I have seen them on the steering colum just infront of the dash they look ok they but you would need to hide the wires somehow so it looks neet.
  • 1 month later...
Something a lil different that the guy in the shop laughed at when I suggested it. I wanted to be able to quickly mount it anywhere didn't mind about the cables dangling as I wanted to quickly remove it when I got out the car to the glovebox. I was originally going to use the velcro everyone has suggested but I had another idea.
I wanted something with a ball joint so u could swivel it in any direction. I ended up getting a suction rear view mirror, not a large one but one that was about the size of my blitz sbc id3 and power meter controllers. I cut it to size, very lil had to be cut off depends which one u buy and stuck the displays on with the usual high bond double sided sticky tape. I then position it whereever I like, usually on my R33 its just to the right and down from my clock it suctions their wickedly, has never fallen off and is quick to put up and down again. I also at times stick it to the windscreen.
For a total cost of $10 its a lot cheaper than the apexi stands which can only swivel one way a lil limited for my liking. Everyone that sees it cannot believe it only cost me $10 cos it looks so good and easy to do!
Well hope this gives u some ideas!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
