hi guys
just a few thing to get rid of!
a jvc unit kdsh9105 cd/cdr/cdrw/mp3/wma/pic
3 rca out, sub cont, aux in, download your own pix, colour, 7 band eq, 4 by 50 and lots lots more
bought it for $870 sell was $530 in box with all bits and peices, as well as a free stacker brand new in box 12 disk jvc ( never bothered to hook it up?). will take 450
http://i7.photobucket.com/albums/y260/sqwa...csfromnz288.jpg
http://i7.photobucket.com/albums/y260/sqwa...hy/EEBAY001.jpg
i also have to older type alpine vr 10" woffers in a band pass boxwith a perspex top if anyone is intrusted?
i would take $110 na i will take $90 for it? they do pound!
http://members.optusnet.com.au/~ewilson80/gallery.html
nesa in car dvd player!
draw type comes with an eye remote sensor and remote as well as a 6 month garanty!
this unit is a factory seconds unit so its not perfect but prity dam good for the money. $190 na i will take 150 for it!
http://i7.photobucket.com/albums/y260/sqwashy/dvd001.jpg
http://i7.photobucket.com/albums/y260/sqwashy/dvd002.jpg
http://i7.photobucket.com/albums/y260/sqwashy/dvd003.jpg
hum 140
how about a momo gear knob?
in used condition but hardly any scraches. nice and heavy!
http://i7.photobucket.com/albums/y260/sqwashy/knob001.jpg
http://i7.photobucket.com/albums/y260/sqwashy/knob004.jpg
i want 40 or up because i sell these at work for 179 so its a dam bargan!
mabe some more stuff coming up!
send me a message if you are intrusted or need some pixs/ info
thanks pete
Edited by japcrp
https://www.sau.com.au/forums/topic/79686-japcrps-clean-out-sale/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
