I went backwards in the old skyline with ansafc but it imporved the fuel econ heaps and made for a smoother aplication of power.... Id recomend it if you dont want to go to a pfc...
Althought in saying that i reckon pfc set up properly will be better bang for your buck... and you motor will last longer tuned with a pfc properly...
There are many who say they can tune a safc but the reality is that if you get it wrong you will lean out and something will go bang.....
hey geno8r  :) wat other mods have u got on ur car ??
Performance Mods would include:
T3/T4 HighFlow'd VL Turbo
GTR FMIC
GTR Fuel Pump
S-AFCII 'Dyno Tuned'
GReddy Profec B Boost Controller
3" Exhaust Turbo Back 'inc. HighFlow Cat
K & N Pod Filter
Irodium Spark Plugs
Blitz Open-Atmos BOV 'not exactly performance, but helps keep turbo flow'in
Brass Button Clutch
Always run BP Ultimate
Stock RB25DET engine.
Stock Headgasket, Injectors, Cams etc.
Thats about the gist of it...
Here's a good dyno sheet showing my first performance tune with the SAFC
The lowest line is approx 230 rwhp with the SAFC running stock A/Fs ‘eg no tune’
The next line up approx 255 rwhp was after the SAFC tune ‘still running stock 7psi’. The top line 292 rwhp was when running 12psi on inferior fuel. Since then using ultimate & a leaner tune have now got 309 rwhp on 12psi.
EDIT: You didnt have to delete your post but I've answer your question anyway.
justin911 asked "is wizzles killowatts or hp"
Wizzles as in Kilowizzles...KiloWatts
If it was Hp I spose I would of said Hisopizzles
lol Gizoogle has really influenced me lately www.gizoogle.com
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
