Why do automatic tranny cooler lines run through the radiator?
Thats the question.
Do only autos come with the radiator that ducts them in?
Can i bypass it and run just a front mount AT oil cooler or does it assist in the cooling or oil thining/thickening?
Cheers
Thats the question.
It's an oil cooler and generally all auto cars have one in the radiator. Yes you can run a separate trans oil cooler - it actually extends the life of the tranny esp if you plan on engine power boosts.
I know its an oil cooler the point of the question is why is it ducted into the radiator
and what ramifications will it have if not used but just running a big tranny oil cooler
Cheers
Cheers
It's cheaper to do it that way in mass production, plus it allows the tranny fluid to reach operating temp quicker which aids driveability. I've also read somewhere of one manufacturer (toyota from memory) claiming that it reduced emissions by optimising operating temps, etc.
It is almost invariably better to disconnect the factory cooler and run a separate air/oil trans cooler. The factory type is small and you can usually fit a larger aftermarket type that gives better cooling all round and will extend trans life. For a standard car the factory cooler will do the job, but boosting engine power or continuous engine load (eg towing) makes fitting an aftermarket cooler mandatory AFAIC.
Downsides - finding the space + the trans will take longer to reach operating temp esp in cold climates (eg winter in melbourne)
I know for a fact there are atleast 2 different radiators for r32s. One is an auto one, with the trans cooler part, one is a manual one without it. Obviously I'm not 100% if *all* auto ones got the auto radiator or if *all* manual ones got the manual radiator but it would stand to reason.
I would probably keep the transfluid running in to the radiator then in to the external trans cooler then back to the gearbox.
Setup that way would no doubt help absorb peak hour traffic trans fluid temps when there is no air passing through the external trans cooler.
when i fitted a trannie cooler to my R32 auto, i found that it did indeed have the factory AT oil cooler on the bottom of the radiator...
i simply run the fluid through this cooler, then through my aftermarket cooler, then back to the trannie :rofl:
How would running the AT cooler lines through the radiator assist in keeping the fluid cool?
Granted it getsit to operatin temp quicker but is this one of those things that pulls both ways?
I will be replacing my radiator with a manual one so i wont be running through the radiator but will the setup be okay still?
You don't want your fluid too cold, it doesn't behave properly. They make these fluids to behave in a certain way in a certain temperature range. Outside the range and they don't work properly. I run mine through both the radiator and the cooler in the front drivers side air dam.
The liquid (transmission fluid) to liguid (water in radiator) cooler is the most efficient. Liquid (transmission fluid) to air transmission cooler is not as efficient, so it has to be larger. The Stagea (have a look at the transmission cooler thread in the Stagea section) has both standard, I simply replaced the small standard air to fluid cooler with a much larger and more efficient Davies Crag transmisson cooler. But I kept the fluid to fluid cooler as well, can't have too much transmission cooling when towing.
As long as you use a large enough air to fluid transmssion cooler, then you can live without the fluid to fluid cooler. Make sure you put it in the line of airflow from the radiator fan, that will helpo when in traffic, not moving much for long periods.
    • Thanks mate   It's all coming together finally. It's just a better racecar now and also yeop I've pulled my thumb out and committed and the combo seems to be gelling Depends what you mean by not much more haha There's at least a 1.19 in this My fastest lap posted lost 3.5 tenths in T10 and this was on 80% power and 5 heat cycle old tyres The next session/ lap we did we were up 4 tenths with the car out of the final turn T12 accelerate straight and going with 1 or 2 tenths to come from the power to the finish line and the shifter/gbox combo stopped selecting    So we wouldve had it. The whole thing..   Also repeated this the very next lap up 3 tenths out of T10 and same issue Add some news tyres and we good   Looking forward to a break then yeop WTAC and see if we can actually have a decent run
    • Thanks,managed to find one from Australia.
    • Yeah pretty impressive hey, good to see quality products not over-shooting their prices. That's what drew me to buy the hypergear turbo, just a shame I've never got the chance to see it in action
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
