I used loctite on mine, as I couldnt click it off at 330ft/lb. I sparingly used loctite supernut lock which is the lower grade blue type.
I'd advise against using stud lock (red) or the retaining compound (green). I've seen bolts permanently attached with these grades. Once I saw a coarse threaded bolt that wasn't that much larger than the balancer bolt which we couldnt undo. Not with a 3/4" rattle gun, not with an 1" rattle gun and not even with an 1" rattle gun that used an 1" air line!!!
Note to self: Only use BLUE loctite!!
I really dont see a point in replacing the crank seal as its not leaking and would be more trouble than its worth IMO.. I am however doing the camseals and half moons, replacing the tensioner and possibly the bolt for the tensioner and the stud for the idler. The idler itself feels very smooth so im thinking not to bother replacing it... Any input?
Cheers,
Deren
Cheers,
Deren
You're better off replacing the idler. You'll kick yourself if you have to pull the whole thing down again in 10000k's if the idler gets noisy. They're only about $70 - do it now or suffer the pain.
Just posting these details as the search on this forum just sux now. Can't go past a couple of months.
BSC Motion Technology
3/ 1968 Hume Hwy Campbellfield VIC 3061
ph: (03) 9357 7515
Idler: NSK 56TB 2801 B01
Tensioner: NSK 60TB 0683 EA7L 806
Now I spoke to Steve when I got mine there and they were only about $120 for the pair. They apparently had hundreds in the warehouse.
Is it really important to torque the crank pulley bolt to exactly 446-466Nm?? Thats a huge amount of torque and the wrench needed would be very expensive. Im planning to buy a smaller one for lighter jobs but i cant even find some where to higher one like that. Someone said they just did it up as tight as they could, and it was ok. I'd prefer to torque it to the right tension but sounds as though it will be difficult...
Deren
Deren
Yea you need a 3/4 drive torque wrench , i have one but i'm in Sydney otherwise i would lent it to you .
As long as you do it up very tight with a big bar it should be o.k. , i always do them up with a torque wrench though .
  • 3 weeks later...
Recently put the crank pulley bolt back in and did it up real tight, now i cant undo it to make changes! I didnt think id need to undo it so i did it as tight as i could. I've already broken about 3-4 breaker bars!! Can anyone help me to get this bastard undone?? :(
Thanks guys,
Deren :(
Deren, maybe call lubemobile and tell them to bring a 3/4 rattlegun. Has to be worth paying for that. I have a heavy duty pulley pin spanner I made that should hold the load as well to make it easier and maybe you could buy a 3/4 breaker and socket.
I'd come and help but still recovering from back surgery.
Thanks again for the reply Geoff. Would a rattle gun fit in there with only the radiator removed?
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
