C'mon SAU ACT- let's make a show of this!
"Event Details:
The third Annual ‘Marques in the Park’ will again be held at John Knight Park in Belconnen ACT on Sunday 20 November 2005.
The event is open to all vehicles from Modern to Vintage, Modified to restored. Race cars and bikes
In 2004 over 220 Vehicles attended the event, held among plentiful Shade trees and open grass on the shores of Lake Ginninderra in Belconnen.
This year we have organized:
· Breakfast at Rydges Eagle Hawk from 6:30 am ($12.50 per head)
· A cruise to the Venue, departing from Rydges Eagle Hawk at 9.00am, This will allow participants to enjoy an organized run to John Knight Park and then set up for a relaxing day of Vehicle spotting.
Facts and details
The display at John Knight Park will begin at 10.00 am and go until 3.00 pm
John Knight Park is on Aikman Drive Belconnen
Entrance to the park is via Lake Ginninderra College car park.
Entry is FREE for participants and lookers
Shaded areas and open grassed areas, for parking and relaxing
Set up for clubs and individuals from 8.00 am
Espresso coffee
Food stall selling hot food and drinks
Display area close to shopping mall and fast food outlets
$10,000,000 PLI coverage
Vehicle access and movement is allowable all day, with a 5kl speed limit.
Council of ACT Motor Clubs event.
Club BBQ’s permitted in the Park
· Special display by the FPV& XR Owners Club of the ACT
Contact me at [email protected] if you need more info
or go to my web site http://members.iinet.net.au/~kustomb
BRUCE
Ph 0408 652 107"
"Event Details:
Facts and details
Espresso coffee
BRUCE
Ph 0408 652 107"
OK, keep us informed - will keep the diary free to attend.
Marc2
Marc2
Or how about you put a reminder in your diary;that way I don't have to "keep you informed",ya cheeky bugger,LOL!
did anyone read my idea about the bbq lol??
I think it's because there is Maccas, Hungry craps, Red Rooter, Subway, Pizza hutt and Ali babas all right there on the lake, so maybe we could just hit up one of those places
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
