HI Everyone,
I have a Greddy ProfecB spec2 and the boost warning feature keeps coming on when whenever I get near 12psi regardless of what it is actually set at
I can rectify this problem by resetting the limit value down (to any value so long as its less and not more thatn the original setting) but that only lasts until I reach the set boost a couple of times and then it goes back to flashing the waring over 12psi or so.
The warning level can be set at 16 psi, but the warning will still come on as above.
I don't believe that boost is spiking as I have had it on a dyno and I monitor the boost guage regularly and it still controlls boost effectively.
I have played around with all of the settings but I am at a loss.
Has anyone else had this problem with their ProfecB or other boost controller? or can offer any suggestions?
I have a series 2 R33 GTS-t
Thanks for your help
https://www.sau.com.au/forums/topic/80226-greddy-profecb-problems/
HI Everyone,
what is your max/peak boost when it cut out?
The warning light comes at about 12psi, sometimes as earlie as 10.5 psi.
The problem doesn't seem to have any effect on the units ability to controll boost, its more of an annoyance that the unit keeps flashing and beeping.
if it doesn't cut out when the warning light flashing then check for loose wires! if live in the western area i can give you a had to sort it out, pm me if you need help! :D
What's the peak when you get the warning?
reset the peak, fang it... if you get the warning check the peak. It'll most probably have peaked over whatever it is you have your warning set at.
I allways thought that the warning light was only a warning on the pbs-2.Not a fuction that cuts the boost as well.
You can set the warning to do nothing. Red "Warning" mode screen, and a "0" setting (this sets it to do nothing).
Or you can set it to something by setting this to a number. Then basically, if the profec B reads a higher boost pressure then it will default the boost setting to whatever you had set on the red warning screen.
HI Everyone,
Yeah have exactly the same problem. Not sure what causes it yet. Had to set the boost warning 10psi over normal boost to avoid it. Also have the problem of over boosting when i floor it at anything over 3500rpm. Nothing i do with the settings will fix it. Really bloody annoying. Going to change to a jaycar one instead.
Gunna put the shit Greddy thing in my deisel van.
My Greddy Profec B spec 2 works fine. Really fiddly but fine.
I'm on full boost(13psi) just before 3000rpm (stock turbo) and it holds boost perfectly (see graph)
Mine holds boost fine too on normal spool up. But not when smashing it above normal full boost rpm. Dicked with start boost and gain. Can't stop it over boosting. And the warning is stuffed too.
At the moment the limiter is set to 0, so its not limiting the boost only flashing its head off.
Peak boost never goes above 14 psi and the warning is set at 15 psi
I have a black head unit.
I have no problems with boost controll as my dyno graphs will show either a spike or flat progression depending on how I set up the unit.
I Don't think that it is wiring as I can change the warning setting from 15.3psi to 15.2psi and it will only flash when 15.2psi is reached. But this only lasts till i hit boost 3 to 5 times (any boost ammount) and then it will start flashing on boost levels above 12psi?????
So when your is ebc off it boosts fine but when the ebc is on no matter where it is set it overboosts ridiculously.
Why is that.No matter what you have it set on. :confused:
I have the duty cycle at 32% which gives me a nice consistent 16psi on normal roll on spool up. But will spike up to 3psi when smashed above 3500rpm.
Also on the drag strip with around a 4000 -4500 rpm launch the peak boost for the whole run doesn't get above 13.5psi. Got me stuffed.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
