sorry to go off topic but dont you have an rb26??
yep, i do, but since i cant afford to keep the car if i dont get some money some how, i've decided that maybe i should sell the 26 as a full rwd conversion kit to some one, and buy a cheaper engine to put in, that way i can still live for a few months before having to look for a job...
how much you guys reckon i can get for a complete rb26 engine with turbos, harness, power fc, gearbox, cross member, plenum, injectors...all that shit...
Meggala gets a workshop to do all his work. You are better off with someone who did the conversion themselves.
There are 3 SR cefiros in Sydney that I know. You should check them out. You are welcome to come check my conversion out and have a chat about it. PM me if you like
The workshop who did my car didn't exactly to a good job either sky80 so you wanna stay away from them, whoever they were. Listen to too_much he does good work, if you need to look at my car you're welcome to check it out also.
BHDave commented on my gearbox mounts being good so you may like to copy that but that's pretty much it.
too_much if you wouldn't mind would you please keep it in the thread so others (like me) can look at it? and so I can (with permission) use it on my website? :)
The conversion from stock RB20det manual to SR20DET manual in a cefiro is pretty straight forward. I'll run through what I did to make it all work
For starters, You need to pull the old lump out. I did this with the engine and gearbox still bolted together. This is always the easiest way to pull a driveline out. This is all pretty straight forward.
Remove all the cooler/intake piping
Take out the radiator
Disconnect the wiring loom from under the dash and pull it though to the engine bay
Disconnect the fuel lines, and throttle cable and any other bits that attached the engine to the chassis.
Unbolt the engine mounts
Lift
While the engine was out, i gave the engine bay a scrub with a scrubbing brush and scourer and degreaser to get rid of the toxic RB stink through my engine bay.
The SR engine mounts will not line up with RB crossmember, so I used an S15 crossmember (which bolts in with no mods), complete with S15 steering rack (although an S13 one will work just as well). I used S13 steering arms as the S15 ones were too long. The standard lower control arms remained in place.
I bolted on the flywheel, button clutch and gearbox while the engine was out of the car, also put the stainless manifold and S15 turbo on while it was still out. The more you can do on the engine before you install it, the easier things will be. I also fitted the mount on the engine for my oil cooler kit.
I put the engine and box in while bolted together. There is ample room to do this. The engine mounts lined up fine. I was lucky to find that the standard RB20 tailshaft was the exact right length for my driveline, and had the same output shaft splines.
We had to modify the SR gearbox crossmemder, which took about half hour. The mounting holes needed to be elongated by about 8-10mm, and part of the lip needed to be ground off. This doesn't have much effect on the strength of the crossmember.
I used a stock S13 radiator, which fitted the standard bottom mounting holes quite nicely. I did have to make custom top mounts out of thin aluminium that i bent to shape.
I made up a mild steel intake pipe and set about welding up some intercooler pipes for my fmic. Having a tig welder handy makes life easy. Also fitted a cusco catch can and plumbed it in
There is some wiring trickery involved, but i wont go into that here as i can't remember the exact details. You just need to have a SR20 wiring diagram/pinout handy, and the same for the RB, then match things up
The rest is just tidying stuff up. You will need a wheel alignment if you changed the steering rack. You will find the tacho will be out, so I got an aftermarket Pivot tacho.
I made my own front pipe and 3in cat back as there was nothing readily available
The finished product
Since then i have fitted a few more things to make it faster and handle better
Sorry about being so longwinded, but you did ask! :)
dude...you're a legend...some one pin this thread :)
there's so much space in there, V mount :D
too_much_boost thank you very much...the longer the wind, the better it is :) wanna come around and gimme some pointers when i get back from o/s? ;)
so s15 steering arms are too long, is that the arm that come from the steering wheel? or is it the radius rods?
I reckon now that i've done it once, i could do a drive-in, drive-out conversion in a weekend. The stuff that takes time is making the exhaust and FMIC piping.
The steering arms are the bit that goes from the steering rack to the tie-rod ends
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
