This is a group buy for BRAND NEW motorola V3 RAZR mobile phones.
Specifications on the phone can be seen at the link below:
http://direct.motorola.com/ena/web_product...productid=29601
There needs to be 15 - 20 buyers to make this worthwhile for everyone...
Price will be approximately $590 - $600 per phone & they come with 12 months manufacturers warranty.
Payment is by direct deposit. Pick up is avaliable to Brisbane members.
Just post interest on this thread...
Rob
https://www.sau.com.au/forums/topic/80365-eoi-gb-motorola-v3-mobile-phone/
Rob
Dont want to burst ya bubble but these phone can be purchased without a GB at a better price than that and still with 12month warranty.
If its only cause you want one then hit me up and i'll give you the details and save you the hassels with a GB if you like???
Cheers B
hmmm I can get them for $450 aussie ;)
try and be a little bit more discrete mate.
$450 aussie which means your importing them in. Normally means no warranty and no back up, the item is different and ou can check via the serial port numbers on the phone.
There is currently a HUGE mobile scam with people selling phones for less and the buyer gets stooged with a crappy toy phone :chairshot
Guest
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
