i have built a new catch can for my r33 gtst and dont know where to plumb it in
have dune the serch on the fourm but could not really tell where all the hoses were going to so have attched a photo of my car and drawn some arows on so if any on could help me out that would be great
i have a catch can with a breather on top and too hoses cumming out from the top and a dranege plug on the bottom if this helps
jut added pict of the new catch can i built
https://www.sau.com.au/forums/topic/80507-catch-cans-and-fitting/
Or you could take off the hose where the blue arrow is that goes back in near the turbo and plumb that into the catch can and the outlet of the catch from where you removed the blue arrow hose (If you get what I mean) With that you will still get abit of oil mist going back into the intake.
Having the filter breather ontop of the catch can makes it (cop) illegal either way you do it.
Im prett sure you would want to do it this way, or else your not passing the air from the second cam cover through the catch can/oil-air separator at all.
So youve paid for a catch can and its only doing half the job.
Hmm yes you will as the side of the blue hose I am reffering to is getting the combined oil/air from both the cam covers and then feeding it back into the intake. So you unplug it from the intake and into catch can and then back into the intake.
So you are taking the combined oil vapour from both cam covers and running it into the catch can and then back into the intake
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
