wrxhoon,
   Nice time, I think with the clutch you should bed down a flat 12. I will be there once I get my clutch in. What tyres did you run?
Yea i should be able to run a flat 12 or even a high 11 with a good clutch , i will be looking for a Nismo twin plate i think .
Toyo 265x35x18 in the stock 18x9 rims and full street pressure ( 38 psi ) . traction wasn't a problem , the clutch wouldn't grab at any amount of rpm , i even went down to 2500 for a 2.37 60 ft .
What kind of clutch are you going for ?
Jerry have you listed your mods so far on the M-Spec? Nice time with the stock clutch. Mine is slipping at high rpm launches as well but i figured that was expected with 70k kms done on it.
I'm heading to Japan (tommorrow) to load up two suitcases with stuff. Here's praying customs dont notice.
My clutch was holding 100% on road and while tuned , its just when you sidestep @ 5000 + to much heat in to it and then it would kepp slipping especialy on gear changes . On my last run i only used about 4500 ( not enough realy for a clean launch ) and that was my best run .
Mods are as i told you before , gtss's , p f/c , 550 cc Nismo injectors , hard i/c pipping , ( stock i/c ) pod filters ,( for now , still looking for a stock airbox ) ebc ( 1.2 bar) , hks front pipes ,( stock dumps , they are s/s on the 34 ) 3" catback ( very quiet )and thats about it . Its a very responsive car with that set up .
How long are you in Japan for ? good luck with the shopping list .
Check your p.m
I was out there watching as per normal.
Some people just don't get it. There must have been atleast 15 different cars that had no idea how to stage!! It just holds up the whole night.
Highlight of the night was the dark red s14 throwing a good burnout all the way up to the staging line and then hitting the starter when he came over to tell him off.
Good to see some r32 gtst's out.
The inability to stage thing really pisses me off. It shows that they clearly have either never been to WSID to watch others race, or they have watched but failed to pay any attention.
That red S14 thing was quite funny. Yay lets stand directly infront of a car that's doing a burnout to teach him a lesson, oh shit he ran into me. Quite suprised the driver didn't get out and give him a mouthful. It was only about 15mins earlier the announcers said over the PA "Do not do a burnout across the line, we don't care how big your burnout is before the line but don't go over it".
From what I could see he hadn't passed the line yet :D
Yes that's right.
As you approach the line you will see on either side of your lane (the red painted bit) a narrow white line (which is actually about 20-30cm wide I believe). Slowly moving in will initiate the first 'pre-stage' light, moving forward a few cm again will initiate the 2nd light (you are now ready to race).
If you happen to roll too far forward and the 1st 'pre-stage' light goes out but the 2nd staging light stays on don't panic just stay where you are. It just means that you can't move forward anymore otherwise you will breakout (red light = disqualified).
Many people make the mistake of quickly trying to reverse back and then drive forward again into stage however before they can do that the 'starter' has already started the staging sequence and you'll screw up your run and timing.
Their is 0.4sec between each of the yellow/amber lights before the green lights up. I usually release the clutch when I seen the 2nd (of 4) amber lights 'go out'. From this I was getting consistent 0.1-0.2sec reaction times (which don't effect your time on wednesday nights but it's the easiest way to beat any car you are racing against).
yep,i done that. practise makes perfect i guess.
ill be getting there at 5pm next time,way too many cars.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
