Pics available via email so please if ur interested leave email addy.
GFB Hybrid blow off valve + Adaptor $200
complete kit including r32 adaptor and weld on adaptor for any car. piece of vaccum hose, plump back return pipe (piece of radiator hose i found that fitted) I also have a spare trumpet as all parts of the BOV screw in, so you can have it plumbed back or change the adaptor with a trumpet and have them both to atmo (loud).Both trumpets are slightly damaged doesnt affect sound, were rubbing against I/c pipe. you can order spare parts like trumpets and pipe blockers, i just got a part no. and ordered thru autobarn.
ink to BOV http://www.gofastbits.com.au/index.php?par...b_option=hybrid
O.S Giken Super Single Clutch with aluminium cover plate and lightened Chrome-Moly flywheel for R32 suit rebuild. Details on clutch specs found here
http://www.otomoto.com.au/supersingles.htm
Adelaide clutch services quoted bout $600 to rebuild needs
machining and new plate or you can order the replacement plate at
http://www.otomoto.com.au/overhaulparts.htm
perfect for street or drift rated at 380hp, brand new this thing costs $1645!!
Was an excellent clutch, heavy pedal feel but i liked it like that. Due to the way the clutch operates it has a slight rattle when foot is on clutch (like a twin plate noise) which led me to believe it was a twin plate. When i got a quote to rebuild it the price was to high so i just bought a new clutch only to find out its a Super Single otherwise i would be keeping it they are a fantastic clutch.
$350 neg.
Red and White GT fender badge 1 only $15 posted anywhere!!
also stock R32 fog lights $30 the pair.
can send interstate at buyers cost.
cheers
https://www.sau.com.au/forums/topic/80527-32parts-os-clutch-bov-driving-lights/
hey just wondering what piece of radiator hose u use, as i have the same bov but haven't found any hose for the plumb back.
sorry mate not to sure what kind of hose it was i just drove to my local autobarn and grab a heap off the wall and keep trying till i found one. most places should let u do this they are normally helpful.
no problem, thank mate!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
