Originally posted by MIZ.33T
i just woke up........... whaaaa wat happened to my New Years Day? gone!
Your New Years day was just reversed.. u spent the time u normally sleep, up and at a beach!
But it was well worth it rite???? P.S Sand pockets are funny for 3rd parties..... hohohoho
Originally posted by IR34I
hehehehe all i can say lucky linus is at work :(
otherwise heheh she would probaly tear the little guy to shreds :D
hehehe..what are u saying Alan??? it wasn't my jeans that Helen wore :( i got OWNED just by laughing at her misfortune!!! some people cant take laughing at!!!! :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
