D1 drift and racing intercooler kits - one of the highest quality kits on the market. Now can be purchased without the a group buy at a extremely low price!!!.
For the next 10 kits only all piping kits are delivered for $350 and full kits are $530.. number of kits at this price left = 10
SPECS
Made from polished aluminium with no mandrel bend marks on any of the pipings. Piping is 2.5" and is very similar to the hybrid kits. The flange on the end of the piping is bigger than the hybrid kit for added support.
Silicon joiners are triple layer with chaffing on the third layer.
Clamps are stainless steel
All kits fit perfectly on the R33/R32 and the s13/180sx. When these were manufactured they were also tested on sample cars and the samples have also been tested in Australia. Many people have bought these kits without a single complaint
Will fit most hybrid coolers.
BONUS: All kits come with the nipple to hook up the turbo boost line too. Save a few $$$
Warranty
All kits are backed by an australian warranty 1 year.
Price
$370 delivered for the piping and $550 with the cooler (600 x 300 x 76 mm)
Arrival
Here now ready to go.[/color]
https://www.sau.com.au/forums/topic/81321-drift1-racing-intercooler-kits/
  • Replies 104
My aussie supplier wants them out the door!!!! So I have the go ahead to sell each kit at $390 in a group buy or $420 without GB... Pm me or reply for more details. Be quick!!! at this price they wont last...
Ive already done a fair bit of mods to the back of the plastic part of the bumper and the front section of the chassis rails to mount the intercooler in there. As far as I can see I just need to cut and shut the two lower pipes to fit the extended end tanks, possibly using a silicone joiner, if not re-welding. This seems the best option short of making a custom set of pipes, which looks like costing around $300-350 in stainless mandrel bends and parts, let alone labour and hassle.
probably will be the cheaper and neater option to modify the d1 kit ....
I have a few kits at home now I will be taking a few picture of them and maybe tomorrow of next weekend putting it on my car and taking it down the drags to give it a test.. :cheers:
How do the piping kits fit in with the factory piping? Does it bend round and come back to the factory intercooler piping? Or does it curve round and come back over the top of the radiator and fans?
it curve round and come back over the top of the radiator and fans? yes that the one..
Just off topic: My mate has a s13 and just put one of my cooler kits on it. My car would be a mid to high 13 if I had decent tyres otherwise it is a 14.051. Anyway he flogged me (2 cars ahead at 140k) and this is the only mod he has done. Oh and apart from the fact that he forgot to hook up the wastegate :rolleyes: 15 PSI he was running. No ping either... Maybe because the cooler is working well - hot on the turbo side and freezing cold on the other...
hey raf, u have an r33 ey don't you?? during the install do you need to move the horn at all?? My horn is mounted next to the fan protruding in front, but the hybrid install ionstructions don't mention it. Any hints for install would be much appreciated.
Cheers
I just installed mine on sunday :) ... Yeah I had to move the horn. I placed it on the bonnet hinge bolts.. The wired will reach it you unclip one of the tyes...
IT took me 7 hrs to install the kit but that because I took my time painted painting the cut surfaces so it wont rust and trying to do a nice job... I forgot to get my camer and take pictures :) but I will take a few picture after my camera is charged an post them up...
I got an extra 1 psi and really noted the difference after I reset the ECU... if I take off like a grand ma, first gear starts spinning the wheels after 4000 rpm and spins most of second gear :) little chirp in 3rd.. Once I start playing with the boost then I should see some action...
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
