PFC HELP reward offered possibly alcoholic (If that is your thing)
Hi all. I am trying to find out if the PFC is compatible with my A-LSD on my R33 GTS-T. I have searched the treads and come up with no conclusion, It works for some and not for others :confused:. So does any one with a PFC want to come to my place (or me to yours) and plug their PFC into my car and see if I get a LSD error or not, I really want to put this issue to bed! As stated earlier reward offered :uh-huh: Thanks guys!
my brother has the same problem. We tried on the weekend, series 1 r33 gtst with ALSD, plugged a brand new PFC in and the pfc wont communicate with an alsd, switches to fault mode and will only spin one wheel. Your best option would be to get an emanage, as its a piggy back system. any questions feel free to pm me.
Yeah this is my whole problem Many peoples dont work but Erins works fine :confused: So I want to see if I am one of the lucky ones or if I will have to go to the emanage/Profec e-01 combo
Andrew, it's ben covered recenly in NSW. Moanie and a few others tried it and it won't work.
Sorry for the bad news mate. I don't know how Erin got by though.
Yeah I was talking to moanie a bit the other day. I read that tread and the fault seemed to range from noting at all, to light on occasionally but diff working, to diff open wheeling :confused:. That is why I want to give it a go on mine and see what happens. I might be one of the lucky ones. I dont want to fork out the cash for one only to have to try and sell it the same day I get it as it doesnt work. I am seriously thinking about Emanage instead of experimenting just to save some stuffing around!
I've been advised not to remove the computer from my car anyway... for different reasons.
But I would say at this point in time, order it and take the car to Gav to have it fitted. Ultimately it's up to you, but if he can get mine and others working, I doubt he'd have an issue with yours :P
A-LSD is a Active limited slip differetial. It is computer controled as opposed to the normal methods. You will know if you have one cause when you start the car two orange lights will light up. One says A-LSD the other says slip.
Personally I'd turf out the old ALSD diff, and get a standard one put in. Plenty of people writing off their R33 lately, shouldn't be too hard to find for $500 or so, maybe less.
I know this seems a bit extreme, but I'd rather be spending a bit more and running full aftermarket management such as proven PowerFC, than just an e-manage. Depends what your goals are for the car.. just a bit more power, or ready for aftermarket turbo, etc later on.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
