ARC front mount intercooler. Dimensions are 230x200x70. QUOTE]
Exactly what Im after....
Please email me a picture of the actual intercooler' date=' to [email protected]
If its what I think it is, I'll make an offer, as its what Im after for my custom intercooler installation to my Series 1 Stagea.
cheers, Brendan
https://www.sau.com.au/forums/topic/81671-arc-intercooler/#findComment-1482871
