Better off with the stock air box & put in a sports filter (like the K&N) and open it up underneath of the box to cold air using some ducting,
unless you are going to seal of the new air pod from the heat which then is no better than an air box anyway. you dont want your car sucking hot air at any cost.
Regards
Damqik
https://www.sau.com.au/forums/topic/8209-cheap-airpod/#findComment-119028
i disagree.... i put on a simota pod filter and it runs much better than the std box... not going to box it off just yet... no real need just now... pod cost me 40odd and the adaptor cost about 35 or vice versa...
https://www.sau.com.au/forums/topic/8209-cheap-airpod/#findComment-119049
Agree with the pod, but for the extra cost of doing it yourself, I found that a partition was very, very worthwhile. Off boost response is noticably increased, especially when the engine is warm.
The partition cost me less than $25, It was just metal backed foam. It was very easy to work as a pair of scissors and a stanley knife or razor is all you need. Get hold of a couple of manila folders to make the template. I took it really slow as I wanted a good job (dont like doing things twice), and it took a total of 2 hours.
And I had enough left over material to make another partition, so if you know anyone else interested, go halves.
Just my 0.02
Steve
EDIT: as far as mods go, perhaps you would be better off waiting and getting your exhaust done first, as the stock one is very restrictive. You would have a far more noticable increase in hp even by just replacing your rear muffler, and you just get more the further forward you go. You must be able to get the air out before you think about getting more in:)
https://www.sau.com.au/forums/topic/8209-cheap-airpod/#findComment-119175
Just my 0.02
Steve
i am going to make one probably within the next month... but as it is already running ok (have an exhaust on it already) it hasnt been top priority as ive been busy as...
do u have the template still? if so can u scan it or repeat the shape in PSP or PS and post it??
or do u have a 33?
https://www.sau.com.au/forums/topic/8209-cheap-airpod/#findComment-119385
I have an R33, plus my 2 year old decided he needed to make a jigsaw out of the template - Sometimes I think I'll never learn to keep things out of harms way:(
It really isnt too difficult, I was putting it off 'cos I thought it would be a painful job but once I got going I really regretted not doing it earlier.
Sorry I couldn't be of more help.
Steve
https://www.sau.com.au/forums/topic/8209-cheap-airpod/#findComment-119388
My car came with a pod but to pass a VIC Roads inspection I had to borrow an airbox, the car felt flat and lifeless, no throttle responsiveness at all, so to all you guys still using standard box GET RID OF IT you don't know what your missing.
I agree with putting a heat shield around the pod too.
https://www.sau.com.au/forums/topic/8209-cheap-airpod/#findComment-119473
Guest Red32sky
Thanks for the imput fellers, I havnt had a chance to get back on the computer for abit so sorry for the no reply! I agree with getting the exhaust first but im abit short on cash and my ex girlfriends buying me the pod so why say no? I think I might do the partition idea doesnt sound too hard. But hopefully ill get the exhaust soon!!
https://www.sau.com.au/forums/topic/8209-cheap-airpod/#findComment-119775
I've run an easy 13.8 with the stock airbox, they aren't that bad.
Even Mines kept the airbox on their GTRs.
Comparisons that are dyno tested have some merit, but then again dyno is not going to produce the airflow conditions on the road so its a little tricky.
The pipe from the airflow meter to the turbo is however crappy flowing and replacing it with a nice metal one is a good idea. I have yet to do this.
https://www.sau.com.au/forums/topic/8209-cheap-airpod/#findComment-119922
Well REV210 all I can say is try a pod and see if you like it, I've tried both and I like the way the car drove with the Pod way better.
The pod might be something to try if I get a requirement for larger airflow. At the levels of power I am making the 800 odd cfm is plenty and less noisy.
Sound effects have a placebo effect on the sensation of speed. If you like the sound thats all well and good, is it actually making more power as a result, maybe...and maybe not if you have an aftermarket panel.
Something else to consider is that in the real world, changes to the air intake make bugger all hp gains (maybe 2-3rwhp) on a stock engined skyline.
https://www.sau.com.au/forums/topic/8209-cheap-airpod/#findComment-120048
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
