The ecu will be going into the rich and retarted load points of the factory ecu maps from the increased boost over standard that your running.
Three Options.
1, Turn boost down to a lower pressure.
2, Get a SAFC and trim the AFM output to fool the ecu. (Bit of a band-aid approach)
3, Get a PowerFC or equivalent aftermarket ecu and get it tuned and get gains in all areas of the powerband.
The factory ecu's a real pain in the nut sack, when you try to make more power then standard.
Was just thinking the PowerFC wouldn't be an option really either as you have an Auto and will lose the factory smooth shifts if you went that way.
Get a SAFC and maybe wait and see what these new Greedy Emanages are like when they become a little more popular.
  • 4 weeks later...
I have just felt the same problem. if I leave my car with stock boost 9-10psi (intercooler, exahust) the car runs awesome. But when I try to boost it up to 12 psi I feel the same problem, low acceration just past 4500 then after about 500- 1000 revs the acceration picks up again.
With the safc how do you trick the ECU, reduce the fuel at 4500? or the whole range after 4500. BUt then the car will start to ping.. If the second then really you cant get much more power with the stock ecu after 10 - 11 psi?
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
