Selling my...
*Bonnet, with custom Carbon Fibre GT Vent.
- Stock metal bonnet with custom centre cut out
- Custom Carbon Fibre GT Vent
- Non Defectable Bonnet (dont be scare of getting defected for this)
- Dummy Bonnet pins
- Good for hot air flow release
- Not a problem with water
- Custom Red in colour
Price:$600
*Genuine Nismo Front BarSOLD
- GT style racing Fins (on the sides)
- GT Style racing lips/spliters (on the side)
- A little cut out for more view for front mount intercooler
- Bar blinkers not included
- Original Nismo Black Mesh
- Nismo via Nissan Dealer RRP: $1000-$1200 Supply
- Original & Genuine means... more reliable, more stronger & is better.
Price:$750
Also selling matching Rear NISMO Bar - $500 *pic below*
Total Price for both $1350
But Buy both for $1200
Sydney Buyers Only!! (Pick Up)
Sorry no interstate buyers as items are to large & expensive even
at buyers expents.
Front Bar - SOLD (Thanks to wogboy)
Side Skirts - SOLD (Thanks to wogboy)
Bonnet & Rear Bar Still for Sale!!
PM me...
Check out pics Below....
Cheers!!
Edited by FILO34
got an instrument cluster to sell me?
hey i think ive seen you at the BIG W in carnes hill... is dat you?
Sorry mate, no cluster for sale....
im always there i guess...so yeah that may have been me.....(if ya talking about my car)
PM Reply'd.....
Also following Question's asked & Answered:
Q: Is the bonnet fibreglass?
A: No, its a Stock metal. But the Vent is Carbon Fibre.
Q: Would you sell the Bonnet Vent itself without bonnet?
A: No, Sorry selling the whole thing, bonnet & vent together.
Q: Is the front bar fibreglass?
A: No, its the original thing, a genuine item so its plastic.
Q: Would you send interstate?
A: As posted No, but if buyer is willing to buy both
then it maybe considered. At buyers expense.
Cheers
wogboy...PM reply'd.
I have a few offers....and so now sale is put on HOLD.
Awaiting confirmation, payment & details.
Thanks ppls....
Don't have it, can you resend please?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
