Would like to congratulate all who attended today and to the SAU NSW organisers for putting on a great day. Was nice to put some faces to the names of a few people.
There were quite a few PB's run today, the most notable being Paul's 10.3@133 in TWO.06L and Stacey's PB of 11.9.
2RISMO also ran a PB of 11.6 and Brad ran a PB of 11.2 in the 200SX. Congratulations. ;)
Post up your times and pics :P I have some pics and videos that I will upload tomorrow.
:P
Charlie.
  • Replies 275
Posted Images
I had an awesome day today. Got 20 runs in and was consistantly running between 13.1 - 13.3 by the end of the day. I ended up doing a PB of 13.160 @ 103.62mph using the std turbo (12psi) which I was pretty stoked about. It was a big improvement on the 13.7 I'd done previously.
Big thumbs up to all those responsible for making today happen, there were definately some awesome times ran today. The day ran very smoothly and everyone behaved, so hopefully we'll be able to have another one of these days in the future. It was also nice to meet a few new people today, although I probably missed out on meeting a few more due to the fact I'm just a quiet lad. All good though :P
Look forward to seeing some pics ;)
THANKS ADAM!!!!!
What an awesome day!!!!!! BIG :P to the organisers!!! I can't wait for the next one!!! get to it bob! ;)
Congrats to stace and paul on their awesome 10.3!!!! :P and to stace and 2rismo for their pbs :)
my pb was 12.646@110mph.... can't believe i did that well!!!! i was chasing that 12.5 after that, but it was elusive! :( next time! :)
Great Day!
so sun burnt :P
Ah well congrats to everyone who got to or beat thir PB's
and Paul with your 10.5 and stace with you're 11.* !! (still love your car ! haha)
thanks for all the organisers for putting everything together and for the food ;)
:P that was me putting on a show for andrew (merli) :(  i saw the guy.. i signalled an apology!  hope they weren't too upset!
What's funny, was that you did that MASSIVE burnout (the 2nd one) and sat there for about 1 full minute smoking them up, and then lined up and completely stuffed up the launch and pottered down away at like 10% throttle ;):P:)
The officials had a good laugh at that one :chairshot
Moved this thread to NSW General section... More people will read it here :P
I'll move it back to the Drift & Drag section after it has run it's course!!
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
