My car is having this weird problem, when I start the car in the moring (or cold) it runs like a dream. But if i drive it for a while, and then stop and leave it for a while (an hour or more), and start it again, it runs like shit. It won't idle, it keeps almost stalling then coming back to life. And when I drive it it will barly rev, and it bucks and carries on, the only way I can get it to go is to pump the throttle. It's hard to explain, but it's a pain in the arse.
The ECU is a remapped stocker (no 180k limiter, 8500rpm rev limiter, spark cut instead of fuel cut....) i'm thinking that the ECU dosn't like warm starts, but i'm realy not sure.
Thanks
https://www.sau.com.au/forums/topic/82461-weird-problem/
hi sav.....ive had a verysimilar problem to this.....now im could be wrong... be but it could be a couple of things.....either u have some faulty coils and basiacally after uve been driving for a while it runs fine but then when u stop for a while the engine is still v.hot so the coils get heat soaked because the car isnt driving and having air pushed through the front....if that makes sense so try taping up ur coils for a start
or go get a leak down test done and see if u r having any leakage (sounds like it maybe)...i only say this cause i was having a similar problem and after checking it out further found that engine was not in great nic and it was time for a rebuild after similar symptoms 2 u...(not 2 scare u)
hope u dont need a rebuild too
good luck
https://www.sau.com.au/forums/topic/82461-weird-problem/#findComment-1495413
The car is getting looked at on Tuesday, I have had problems with the AFM's in the past (a clean with carbie cleaner fixed that). If the AFM's need to be replaced will Nismo AFM's plug straight in without a remap. Just thinking for future mods.
https://www.sau.com.au/forums/topic/82461-weird-problem/#findComment-1504322
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
