Price drop on all parts (price drop again parts must go)
Crazy prices parts wont last long at these prices. Get in quick!!
Gibson Motorsport RB20 Block never used $800 (very rare) $650firm
Tomei 1.8mm Head Gasket $450 now $350 now $300
RB20 Head $400 now $300 now $250
G-Readdy E-Manage $350 now $330 now $300
Short Shift for RB20 box $250 now $200 now $170
Also got a Go-Kart for sale, Azzuro M6H 1998 100s balanced and blueprinted engine, 40mm axle very quick kart won a few races reason for selling is its just taking up space. Bought for $2800 year and a half ago will sell for $1500 firm.
Comes with lots of spare slicks and a few other goodies.
If interested give me a call on 0424868574 (Nathan)
Edited by mait32
https://www.sau.com.au/forums/topic/82556-performance-rb20-parts/
what exactly is the difference between a gibson ms block and a standard nissan one.
gibson motorsport casted this block for the r31 many years ago it was never used and sold to me about 2 years ago. Benie from chasers sold it to me so if you have any second thoughts give him a call.
It is a lot stronger than the standard block this block could handle easy 800+ hrspwr
So is the block just bare?
No plenum nothing?
If so i MAY be interested, would you be willing to freight?
Yes the block is bare no numbers ever put on it never had a piston touch the sides.
If interested call me on 0424868574 (nathan)
is the head complete. ie. lifters/valves/cams?
and if so, are the lifters in good working order.. ie. not rattling.
cheers
Yes the head is complete everything is there that was there when i ripped it off.
if interested call me on 0424868574 (nathan)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
