THE THREAD HAS NOW BEEN CLOSED AND MOVED TO A NEW ONE JUST CUSCO PREORDER ONLY
THIS IS DUE TO UNFORSEEN CIRCUMSTANCES FOR OTHER BRANDS WHICH IM NOT ABLE TO GET THE QUOTE FAST ENOUGH AND THAT THE PREORDER IS CLOSING SOON.
STILL IF YOU NEED QUOTE FOR ANY OTHER PARTS, PLEASE PM OR EMAIL ME AT [email protected] BUT I WONT BE MAKING ANY LIST AS EXTENSIVE AS THE CUSCO ONE.
NEW CUSCO PREORDER - CLICK BELOW
http://www.skylinesaustralia.com/forums/in...st=0&p=1516461&
Probably just a long shot... but would you be able to get the R34 Nismo Key (gold plated in matt finish). I've seen them in Australia for outrageous prices so if you could get them for a good price, that would be AWESOME :rolleyes:
PS: I vouch that this trader is a great person to deal with... total of 2 transactions "so far" with nothing to lift an eyebrow at. :lol:
Good work man! At long last a CA31 brake booster stopper! I must say there is some serious points in that one.
I shall check the money pot closer to the cut off date, but I should be rite to get one.
Im really impressed with that :rolleyes:
Thanks heaps again mate... can't wait for the result :)
Link for one seller and the item:
http://www.envyimports.com.au/shop/category19_1.htm
hey mate any chance of getting hold of some abflug bilstein coilovers for a wgnc34 260rs stagea?
and a price?
cheers
Brad
hi brad, i dont do bilstein as i only trust cusco for coilover. believe me, they are very very good. it withstand all kind of abuse.. drag racing, drifting.. u name it...cusco withstand it.
here are some prices for them
ZERO-1 $1930 DELIVERED (R32, R33, R34, WGNC4)
ZERO-2 $2290 DELIVERED (R32, R33, R34, WGNC4)
Guest DIRTgarage
looking for a price on a cusco front and rear 1.5 way diffs to suit r32 gtr
Both front and rear
Type RS - 1465 delivered
Type MZ - 1295 delivered
Do you deal with trust/greddy parts ?
Would you be able to source the plumback adapters for the Trust Type RS bov ?
Ive been waiting for one for almost 2 months now......cant find anyone that stocks it.
Will check for u :D
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
