Standard internal Rb20 2 litre that is r32 spec , with a high flow vg30 turbo truck core front mount dump pipe. Some 'mines' ecu a few little mods pod etc, blitz boost controller 290 at the wheels.
I have hit some type of cut, Speed signal cut is the theory at the moment. the dyno graph was heading up still when the power was cut on me. This is on 18 psi. This was at barry's dyno, this arvo.
Enjoy :shake:
https://www.sau.com.au/forums/topic/8331-290-at-the-tred/
Guest KILLER-T
Hey this might sound like a stupid question but at what speed did u make peak power.I'm only asking because i had my car on the same dyno yesterday and the peak power and kmh dont add up
By the way top effort with your power output you have to be happy with 290rwhp well done:uh-huh:
https://www.sau.com.au/forums/topic/8331-290-at-the-tred/#findComment-120468
Guest KILLER-T
Ok it made 304rwhp and 1650 lb torque running 1.08 bar i still didnt get to see my car running 1.25 bar i cant work out why it dont boost as hard on the dyno it must have something to do with load on the engine anyway he didnt do a tune we just put it on the dyno to see how it was running. Barry said he would like to pull a bit of fuel out of the fuel map and then i will see a bit more POWER i will go back in a few weeks once i have some more cash
:thumbsup:
https://www.sau.com.au/forums/topic/8331-290-at-the-tred/#findComment-120488
yeah nice power there guys, specially from the RB20 :thumbsup:
a quick question.. FRIGGIN FOOT-POUNDS for torque.. WTF, i dont get it.. is it a straight forward linear conversion like HP-KW or is it logorithmic?
the reason i ask is on the aston martin website (checking out the vanquish after watching bond last night :mad: ) it says the car has 400ft/lb = 541NM..
linear, that would give your car ~2200NM, where'as a LS1 is only 500NM or so.. i dont get it..
someone care to explain?
Shaun
https://www.sau.com.au/forums/topic/8331-290-at-the-tred/#findComment-120734
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
