Hi girls
Thought I'd get your attention!
As you know our girls cruise was a success.
The topics I raised about are slowly going into action.
I just want feedback of what the majority think about these ideas.
My plans for starting a girls car club for sydney??
Yes, that's a definate. My final decision?
PRETTY MOTORSPORTS
I'm looking into designing shirts & stickers.
Shirts in brief description:
pretty motorsports - on the front of our shirts
& in small print - P.M.S Racing on the bottom left of the back of
our shirts. Still need someone to design our logo & font.
But yes everything is in the process. Once everything is organised
I will hold another cruise so we can meet up & discuss these plans.
Anyone know of anybody who can design, please get in contact with
me. Much appreciated!
Cheers!
https://www.sau.com.au/forums/topic/83313-our-girls-cruise/
  • Replies 68
The name sounds a bit gay to me.
Why not just branch off to the already running and successful female car clubs around the country?
Two that come to mind at chictorque and drivnbyheels... I think it's spelt. I know DBH are in QLD and WA... not sure what other states.
But from all reports I've heard, girl "car" clubs dont seem to function too well, hence my reason for steering clear of them.
https://www.sau.com.au/forums/topic/83313-our-girls-cruise/#findComment-1507025
Female clubs compaired to male clubs just seem to be so much more competitive and selfish.
They always like to think they are better than others and above everyone.
Just my opinion and perception of the current female clubs that exist that I've experienced/heard from a source close to the centre of it all.
Everyones not the same and I wish you luck in forming an all female club and I hope your club doesn't fall victim to the same attitudes of other dedicated female only clubs.
https://www.sau.com.au/forums/topic/83313-our-girls-cruise/#findComment-1507070
LMAO, I know of some pretty competetive petty and selfish MALE car clubs, your club would have to be pretty damn bad to match them.
Comes down to your members, I guess, and how you deal with certain situations.
All power to you and the best of luck. You're going to need it.
https://www.sau.com.au/forums/topic/83313-our-girls-cruise/#findComment-1507084
If my memory is working I remember when you joined CT and the stir you caused ... while I wish you luck you may need a better out look on things for it to work.
CT and DBH are both going reasonably well but I'm sure both have had their hiccups.
I've said it before and I'll say it again I'm not sure how an all girls club will work ... chicks are bitches ... fullstop.
https://www.sau.com.au/forums/topic/83313-our-girls-cruise/#findComment-1507113
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
