its quite simple, nissans goal for the GTR was coming up with a homolgated street vehicle that could be successfully raced with minor modifications.
LOL...I wasnt aware that Grp A Touring cars was production car racing :P
They had far more then minor modifications...but i know what you mean.
Its up to the individual...i would love to have GTR toy car, but there is no way i could afford to do what i like to do with my car if i owned a GTR...so it will be different for everyone.
I dont think there is any real argument... the GTR is simply the better car.
Personally i could never own an R34 GTR, having seen the amount of attention they attract, i just couldnt own it....and i have little brother syndrome, i like trying to show up the bigger brothers, may only happen once in a lifetime, but me and my 2.0L will take that moment to my grave :P
But if you ask any owner of a GTR they will tell you that it's a money pit.
ask any owner of a Nissan Skyline and they will tell you its a money pit... not maintance wise but eventually that modifying bug hits you and your pockets are the first thing that gets in infected :)
ask any owner of a Nissan Skyline and they will tell you its a money pit... not maintance wise but eventually that modifying bug hits you and your pockets are the first thing that gets in infected  :(
:lol: not doubting it **JaR**! But GTST owners are better off than GTR owners when it comes to modifying.
I heard you have to be careful if changing the rims with a GTR because it screws with the HICAS/ATTESSA is that true?
lol yeah that i'll agree with, simply coz its got a GTR badge prices are nuts :(
i dunno about rim sizes affecting hicas/attessa?? wouldnt changing rim sizes only affect the speedo reading like on any other car?
yes the 4wd system goes funny when the wheels are not same size allround
Yes i agree GTR's are a money pit..
there is so much u can do to these things that make it go bezerk
i have driven 32/33/34 GTST'GTT/GTR's
there is no doubt that the GTR is a superior allround car.
responds extremely well to basic tune ups.
but as every1 says breaking a RB26 is what us GTR owners fear the most
Break a RB20/25 ??? easy just go out and buy another 1
break a RB26????? not as simple for starters they cost 6-7 G's just the engine it self no turbos and add ons etc
but in the end
i'll never buy a GTST unless it was a 4 door :(
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
