its quite simple, nissans goal for the GTR was coming up with a homolgated street vehicle that could be successfully raced with minor modifications.
LOL...I wasnt aware that Grp A Touring cars was production car racing :P
They had far more then minor modifications...but i know what you mean.
Its up to the individual...i would love to have GTR toy car, but there is no way i could afford to do what i like to do with my car if i owned a GTR...so it will be different for everyone.
I dont think there is any real argument... the GTR is simply the better car.
Personally i could never own an R34 GTR, having seen the amount of attention they attract, i just couldnt own it....and i have little brother syndrome, i like trying to show up the bigger brothers, may only happen once in a lifetime, but me and my 2.0L will take that moment to my grave :P
But if you ask any owner of a GTR they will tell you that it's a money pit.
ask any owner of a Nissan Skyline and they will tell you its a money pit... not maintance wise but eventually that modifying bug hits you and your pockets are the first thing that gets in infected :)
ask any owner of a Nissan Skyline and they will tell you its a money pit... not maintance wise but eventually that modifying bug hits you and your pockets are the first thing that gets in infected  :(
:lol: not doubting it **JaR**! But GTST owners are better off than GTR owners when it comes to modifying.
I heard you have to be careful if changing the rims with a GTR because it screws with the HICAS/ATTESSA is that true?
lol yeah that i'll agree with, simply coz its got a GTR badge prices are nuts :(
i dunno about rim sizes affecting hicas/attessa?? wouldnt changing rim sizes only affect the speedo reading like on any other car?
yes the 4wd system goes funny when the wheels are not same size allround
Yes i agree GTR's are a money pit..
there is so much u can do to these things that make it go bezerk
i have driven 32/33/34 GTST'GTT/GTR's
there is no doubt that the GTR is a superior allround car.
responds extremely well to basic tune ups.
but as every1 says breaking a RB26 is what us GTR owners fear the most
Break a RB20/25 ??? easy just go out and buy another 1
break a RB26????? not as simple for starters they cost 6-7 G's just the engine it self no turbos and add ons etc
but in the end
i'll never buy a GTST unless it was a 4 door :(
