  • Replies 45
ummmmm, yeah........That may be a little difficult. The ***n RTA say they need all the original paperwork to register the car. All this original paperwork was lost by the customs agent when my car arrived......
I cracked the shits in the RTA & told them to call DOTARS in Canberra to sort it out. The RTA people refused & said they needed the paperwork.
I just left the RTA after some more swearing & then I called DOTARS & the guy was like "You should have just got the RTA to call us & we could've sorted it out."......AAAAARRRRGGGGGHHHH
He's gonna send me a certified copy of my Import Approval & then I should be able to register my car.......If not, I'm gonna flip.
https://www.sau.com.au/forums/topic/8342-sat-11th/#findComment-120673
hahahahaaa FAT A$$
$$ BLING $$ BLING $$
geez man it will feel so much better when u get the pulsar on da road davey after all the shit your going through...
ok whats say a 10:30 meet at BK ??? then go to MMMMM together to make a grand entrance ??? i think i might drive my n13 instead of the familia... hehehe not sure yet...
THIS
or THIS ????
https://www.sau.com.au/forums/topic/8342-sat-11th/#findComment-120691
Originally posted by BY BY
Frank: thats a very nice Familia you have there...... why the hell dont you $bling$ it out more often :thumbsup:
im a LAZZY A$$... plus i am up central coast most of the time with the car so thats why im never out WESTSIDE much... though this sat im staying down so it outting time...
they should custom make a BOV just for daves GTiR..
VVVVVVVvrrrrrrrmmmmmmm $$ BLINGGGGGG $$ VVVVVVVRrrrrrmmmm $$ BLINGGGGGG $$
https://www.sau.com.au/forums/topic/8342-sat-11th/#findComment-120719
ROFLMAO!!!!
Frank you funny bastard!!
I thought you sold your N13......
Thanks Tosh & everyone........I may be lucky enough to have it out by this weekend but I'm not counting on it.
I just picked up an AVC-R & SAFC so I now have a hell of alot of power waiting to be installed in my baby.......
https://www.sau.com.au/forums/topic/8342-sat-11th/#findComment-120742
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
