Yes sure it would be easy if it was a 4 stud wheel....but it is 5 stud.
I have measure the distance between 2 near studs and 2 away studs, 63mm and 100mm respectively.
So the question is, how do I calculate the PCD from these measurements?
HELP!
https://www.sau.com.au/forums/topic/83505-calculating-pcd/
Guest DIRTgarage
HELP!
You calculate it by measuring betwwen two adjoining studs/holes and multiplying the figure by 1.7012
hole centres must be used when measuring....hope this helps
https://www.sau.com.au/forums/topic/83505-calculating-pcd/#findComment-1510525
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
